Air/fuel
Hiya i have got a innovate lm2 hand held air/fuel ratio gauge and im going to put in my s2 rs turbo it says in the manual that the air/fuel ratio should be showing 14.7 for lambda 1.0 is this still ok on a turbo?
Thanks for any help
Thanks for any help
OK, so you'll want to see between 0.90-1.00, but ideally closer to 1.00 on cruise (off-boost) and somewhere between 0.76-0.82 on full boost.
If you're driving it to have it set-up, I'd be concerned if it's richer than 0.70 anywhere or leaner than 0.90 when there is any boost involved. Obviously you'll not need to be driving it that hard anyway.
Thanks very much mate will let you know how i get on thanks again
Rst tyrone
Apr 23, 2011 08:51 PM
1374lee
Apr 8, 2010 02:02 PM
Cowboi
Feb 12, 2006 07:41 PM
