Low fuel warning lamp
Old May 7, 2009 | 06:35 PM
Cossy Mike's Avatar
Cossy Mike
Default Low fuel warning lamp
Is there a way to test the Red low fuel warning lamp on a Sapphire Cosworth?
I know it comes on when the ignition is turned on and the Amber screen wash flashes a few times but thats it.
I have ran it as low as I dare before it runs out but I'm wondering if it will ever come on.
Any ideas peeps
Old May 7, 2009 | 06:48 PM
Barry R's Avatar
Barry R
Run out of petrol then see
Old May 7, 2009 | 06:54 PM
Paul_RS's Avatar
Paul_RS
Screen wash shouldn't flash - if it does it means the sensor is faulty.
Old May 7, 2009 | 06:59 PM
Captain500rs's Avatar
Captain500rs
Well run it lower matey lol its nearly on bottom of the red before it comes on.
Old May 7, 2009 | 07:07 PM
Cossy Mike's Avatar
Cossy Mike
The low fuel comes on then goes off.
The screen wash flashes 5 times then goes off. I'm sure it states that in the manual....
Old May 7, 2009 | 07:08 PM
Cossy Mike's Avatar
Cossy Mike
Might fill me jerry can up next time it's low and then run around the streets and see what happens.
I passed you today and you ignored me!!
Old May 7, 2009 | 07:09 PM
Cossy Mike's Avatar
Cossy Mike
When it's on how much is left in?
Old May 7, 2009 | 07:15 PM
Captain500rs
Never ignored you seen ya in your yellow bus mate,give you a thumbs up or was it a finger lol
Old May 7, 2009 | 07:18 PM
Cossy Mike's Avatar
Cossy Mike
Have you done something with your bonnet vents?
Could have sworn they were black when I seen them.
Old May 7, 2009 | 07:33 PM
SelbyRST's Avatar
SelbyRST
4x4 SAFF
Mine came on for the first time the other day, it came on when i was at the bottom of the red, drove to the petrol station about 5 miles away and it didnt run out.. im sure i read in the manual it has 10 litres left in the tank i wouldnt really want to try it though.
My screen wash light comes on when i flick the ignition.. but doesnt falsh. Does the same in my dads car aswell, but thats an xr so could be different.
Old May 7, 2009 | 07:36 PM
Captain500rs
Na probably just dirty lol
Old May 7, 2009 | 07:54 PM
nicksaph's Avatar
nicksaph
as said above if the warning lamp flashers there is a problem with the sensor.
my petrol warning lamp come on when the gauge is reading below the red and on a long run i have done over 40miles with the light on, but round town i don't leave it much longer then 20miles befor i fill up again
cheeRS nick
Old May 7, 2009 | 07:58 PM
Cossy Mike's Avatar
Cossy Mike
cheeRS nick
Do you mean the amber screen wash light bud? mines flashed since day one and after 5 flashes it goes out. When the washer light level gets low it does come on though.
I'll have to leave my petrol to go right down next time and see what happens....
Old May 7, 2009 | 08:16 PM
nicksaph's Avatar
nicksaph
yes mate the ones above the clock. had five sierras over the years mate and non have ever flashed unless there was a problem with the sensor or wiring
Old May 7, 2009 | 08:22 PM
Cossy Mike's Avatar
Cossy Mike
Odd.....
It does work though.
Ignition on and the fuel light comes on steady and the screen wash flashes 5 times then all lights go out.
When screen wash is low it comes on.
I am yet to see the fuel light come on.
Old May 7, 2009 | 08:27 PM
martysmartie's Avatar
martysmartie
Yes as said if either bulb flashes when switched on it indicates a fault, think my light comes on near enough on red. If your comes on when ignition comes on and then extinguishes this indicates bulb and circuit good so maybe sender is not making contact.
Martin
Old May 7, 2009 | 08:36 PM
col93saphcos's Avatar
col93saphcos
my 93 plate fourby flashes the same as saphcosmike's,always has done,mine a facelift model,also done about 30mile with petrol light non no probs but it is concerning when miles away from petrol station!lol,what reg is yours mike?col93saphcos
Old May 7, 2009 | 08:38 PM
Cossy Mike's Avatar
Cossy Mike
1991 (J) 4x4
does your yellow screen wash light flash on start up as well?
Old May 7, 2009 | 08:46 PM
col93saphcos
yes always has done,so i dont know,col93saphcos
Old May 7, 2009 | 08:48 PM
Cossy Mike's Avatar
Cossy Mike
Thanks for your input mate I can sleep easy tonight knowing it's ok.
Old May 7, 2009 | 09:03 PM
col93saphcos
lol,mines maybe goosed to!lol,ach not much to worry about tho,col93saphcos
Old May 7, 2009 | 09:18 PM
Mike Kerbey's Avatar
Mike Kerbey
The fuel warning light comes on at the top of red in my cossie, on my other normal sierra it dont come on until the very bottom of red and when it does the fuel computer says ive got 50miles left.
Old May 7, 2009 | 09:21 PM
James's Avatar
James
in my 1992 the fuel light comes on just under the red and will do about 30 miles atleast with it on, the screen wash lamp doesn't flash.
Old May 8, 2009 | 12:24 PM
A flash on any of these lights is a sign of a dicky connection, on that circuit, I am sure I read somewhere it being 1.8 gallons when red comes on, but best not chance it!!
Old May 8, 2009 | 06:28 PM
Cossy Mike's Avatar
Cossy Mike
How does my screen wash light still come on when its low if it flashes on ignition?
I thought it was just checking itself out?
Old May 8, 2009 | 07:01 PM
The check procedure is they come on for about 5 secs then go off if all is well, there is likely a high resistance somewhere on the line.
Old May 8, 2009 | 09:16 PM
Mine used to work but for some reason they have both stopped lighting up.
155lee
Oct 27, 2015 04:55 AM
Cossiesteve
Ford Escort RS Cosworth
Sep 17, 2015 12:37 PM
Dr. Ickxs
Sep 15, 2015 10:15 PM
landaqmabba
Sep 15, 2015 07:16 PM
Tank Mike
Sep 10, 2015 07:56 AM
