Jacking up.....
Old May 7, 2009 | 06:10 PM
Cossy Mike's Avatar
Cossy Mike
Default Jacking up.....
Whats the easiest/safest way to jack my saff up on all 4 axle stands?
When I jack the front up and put axle stands in place the rear is too low to get a jack under and vice versa.
Ive tried driving up on ramps then jacking up the sides but it's a bit iffy.....
Any suggestions anyone?
Old May 7, 2009 | 06:12 PM
Dangerous Malcolm..'s Avatar
Dangerous Malcolm..
I use them 3/4 size decorative house bricks, and just drive onto them which gives you that extra couple of inches in clearance all round.
Old May 7, 2009 | 06:14 PM
JTECH James's Avatar
JTECH James
Passion for Fords!
jack up under the front crossmember, and axle stand on the arb mounts,
then jack the rear on the diff and axle stand the beam mount points
if you cant get a jack under the crossmember, drive onto some blocks of wood
Old May 7, 2009 | 06:21 PM
Cossy Mike's Avatar
Cossy Mike
Thanks boys, I think I'll have a go with your suggestion James
Thanks
Old May 7, 2009 | 06:24 PM
JTECH James
Passion for Fords!
ive done it a few times
Old May 7, 2009 | 06:40 PM
Rich_bloor's Avatar
Rich_bloor
rich_bloor@hotmail.com
i had a quality jack with my vivaro van, it had a nut fitment to jack it up with, ive got a socket adaptor with my 24v drill, i could jack the van up in seconds. only problem, the top of the jack wasn't flat, it was shaped to the van underneith, so i didn't keep it.
paceo
Sep 25, 2015 08:05 PM
Adam Graham
Sep 6, 2015 06:04 AM
rsturbo27
Sep 5, 2015 05:08 PM
hopper350
Sep 4, 2015 12:53 AM
TrevCos
Aug 22, 2015 06:05 PM
