st 170 juddering when driving
it sounds like a diesel on tick over, has had the oxygen sensor replaced as the ecu showed it was at fault, also its very flat throughout the rev range
Mine has the exact same fault, no warning light and a judder when above 3k revs.
Replaced lambda,crankshaft sensor,plugs,leads & coil pack to no avail.
Last night i changed the fuel filter and it is much better but not quite right stil. Spoke with a number of Ford specialists and they have all said the fuel pump is what needs changing.
Looking into this so will update when fitted....
hi my st170 judders in between 1000rpm to 2000rpm and when over 4000rpm it seems to lose power and won't rev rite up have already changed the fuel rail,fuel filter.crank sensor,air flow mass metre,plugs and yesterday the coil pack but still the same so i,m ready to crack up! anybody with any ideas would be much appreciated
that sounds like the imrc, look on the end of the inlet manifold and you will see a cable , there is a black plastic thing there, they are prone to wear and breaking etc,
the imrc is the inlet manifold runner controller, the is a solenoid on the bulk head which controls it all. its what gives the nice surge of power at 4000 rpm
SMILER258
Sep 28, 2015 09:04 AM
