minimum head thickness for CVH
Old May 4, 2009 | 06:40 PM
Stu @ Claims Care Centre's Avatar
Compensation Specialist
Default minimum head thickness for CVH
you hear a lot of discussion about cossie head thickness but what about cvh`s?
Old May 4, 2009 | 08:07 PM
Karlos G's Avatar
Karlos G
Balls Deep!
What do you mean, how much can be skimmed off?
Old May 4, 2009 | 08:45 PM
yes
Old May 5, 2009 | 09:39 AM
sas's Avatar
sas
should be good!
The cylinder head om my ZVH I built 3 years ago using a Focus RS bottom end had 3.8mm skimmed off it. To get the CR back up. The car went on to 166.6mph at Daddy thrash.
Simon.
Old May 5, 2009 | 04:25 PM
what thickness is that? i have 2 heads here one is fairly thinner that the other but the thicker one has bent valve
Old May 5, 2009 | 08:45 PM
B16CVH's Avatar
B16CVH
Minimum chamber depth after skimming should be 19.60mm
Old May 6, 2009 | 07:22 PM
sillymofo's Avatar
sillymofo
ferriday engineering can in some circumstances re machine the combustion chambers slightly deeper into the head to make up for lost thickness of the head wouldnt have thought you could go too far tho
mk3ste
Oct 17, 2021 10:09 AM
Nov 1, 2015 06:53 PM
Mc5506
Oct 5, 2015 09:57 PM
DAZZER
Sep 30, 2015 08:43 PM
