Removing rear springs
Hi all can anyone tell me if when you remove rear shock will the rear arm drop enough to remove the spring.If not how do you remove them & any tips on fitting coilovers
cheers paul
cheers paul
From: brum/shropshire drives:- frst / escort cossie
paul pretty sure you have to unbolt the driveshaft mate to get the old spring out
then the coilovers are easy as they just bolt on i nthe dampers position....
Ad
Ad
155lee
Sep 14, 2015 07:37 PM
borboyous
Aug 22, 2015 11:17 AM
track.focus'd
Aug 12, 2015 05:53 PM
