Cossie wiring diagram wanted, in English????
Need one of these preferably for a 2WD saph, i do have a copy of the manuals but everything (wiring) seems to be in Italian and i don't want to translate it all if i don't have to.
The car wiring diagram can be got from a Haynes manual as is same as std GHIA, the engine loom is different, I will send you a copy via email but don't know how well it will come out, if no good I'll pop a copy in the post.
As usual give me a nudge if I forget, did you get the piccies ok ?
Cheers, yeah they're just what I'm after, but i need a crystal ball to save me hours trying to find out WTF is wrong with it
I had another look at it last night, live for the fuel pump comes from the N/S rear tail light, and the original wire has been chopped off and not even insulated, there's about 20 other wires in the car the same, i think that's why stuff has blown as it's earthing out on the body. There's a late spec sierra in my local scrap yard, i don't know if the in car loom is the same as mine or not though. But even just part of it would be an improvement.
kosienutter
31
Aug 22, 2015 09:55 AM
y4n
Aug 17, 2015 12:12 PM
muz
Aug 16, 2015 12:57 PM
