powerflex top mount.sorted now thanks folks.
Old May 3, 2009 | 11:02 AM
stevenebm's Avatar
stevenebm
post whore
Default powerflex top mount.sorted now thanks folks.
any of you guys fitted powerflex strut top mounts.i got some through but not too happy with the way they fitted.there were four sections to them,two per strut.one underneath on the suspension top mount and another above the strut itself.tho i found this pic of someone selling a set and they look a copy of the standard ones and not the ones i fitted,they are the two top items in the pic obviously.can someone confirm please.
Old May 3, 2009 | 11:26 AM
Šhatter Box's Avatar
Šhatter Box
there deflex in that pic not power flex
Old May 3, 2009 | 12:42 PM
Christian and Beccy's Avatar
Christian and Beccy
#1 in Spelling Club
I hear alot of adverse opinions of 'other' top mounts, mine has run Powerflex ones for years without any dramas.
The Powerflex ones are 2-piece, if they are those you have, I can't see why you'd have a problem?
Old May 3, 2009 | 01:26 PM
stevenebm's Avatar
stevenebm
post whore
yeh i have powerflex ones.its just that the top mounts seem to be quite thick and can see alot of them compared to when i look at your christian.maybe i have the top bits round the wrong way.
Old May 3, 2009 | 04:26 PM
JesseT's Avatar
JesseT
The best top mounts I have seen are the Escort Cosworth ones. Yes, they are a direct fit to mk3/mk4 escort, they are available from Ford, and they are some three times harder than the standard rubbery ones.
Old May 3, 2009 | 07:44 PM
Christian and Beccy
#1 in Spelling Club
One part goes on the top of the Strut assembly and once it's in place, you can only see a 'collar' peeping through the hole. Then the top part locates into that, but most of that is covered by the metal strut-top.
I'll take some closer pics tomorrow when I am working on the car.
Old May 3, 2009 | 08:05 PM
stevenebm's Avatar
stevenebm
post whore
yeh thats right mate the bottom bush was spot on as described.the top bush had a collar one side and was flat on the other side fitted it flat side at the bottom to meet the collar that was sticking up through.i will take one of tommorow and post some pics up.that will make it clearer.
Old May 3, 2009 | 08:38 PM
Christian and Beccy
#1 in Spelling Club
I'm sure from memory that the wider flat part of the top bush goes inside the metal strut top. But I also seem to recall there really only being one obvious way?
Old May 3, 2009 | 09:07 PM
stevenebm's Avatar
stevenebm
post whore
yeh thats what way i would have thought but the collar bit on the top bush was really big and didnt look like matching up with the collar sticking up from the bottom bush.will get one off tommorow as im sure ive got it round the wrong way.
Old May 4, 2009 | 01:24 PM
stevenebm's Avatar
stevenebm
post whore
had fitted them wrongas christian said tho there was only really one way they could go but as i wrestling the hubs and coilovers in myself i have put the top mounts upside down.everyday is a school day
155lee
Sep 6, 2016 11:10 AM
155lee
Oct 27, 2015 04:55 AM
Topjoe9
Sep 12, 2015 09:50 AM
