Mondeo lights "pulsing"
Old May 2, 2009 | 06:02 PM
Matt-G's Avatar
Matt-G
Default Mondeo lights "pulsing"
So, one of many issues which I need to sort out. Any help would be greatly appreciated. The car is a 93 Mondeo 1.8TD as per this thread..
https://passionford.com/forum/restor...rally-car.html
Basically, the headlights, tail lights and dashboard lights pulse bright and dim when the engine is running. Also the battery light keeps pulsing at the same time. It doesn't happen constantly and seems to be mainly at speed whereas i'd expect it to be more at low revs or idle if it was the alternator that was at fault. It seems to be charging OK as we managed the 80 mile journey home fine and it turns over nice and quick still. I've not put a voltmetre on the battery yet to see what it's showing when running.
Any ideas?
Thanks in advance
Old May 2, 2009 | 06:30 PM
tarmac terriost's Avatar
tarmac terriost
either a earth wire problem or the alt is goosed which is more likely to be
Old May 2, 2009 | 08:18 PM
On a 93 mondy, I'm fairly sure the alt is internal reg/rectifier, don't think these were ecu controlled yet.
But anyway it's a alt problem, not earth, if it is a rythmic pulse, but certainly isn't going to hurt to clean all connections anyway, it's free.
Old May 3, 2009 | 08:47 AM
Matt-G's Avatar
Matt-G
thanks both, i'll get on E-bay and see if I can get a cheapie alternator.
Old May 3, 2009 | 09:12 AM
cabriolet's Avatar
cabriolet
recon starters and alternators for a living fella tab is dead right [as usual] the regulator on your alternator is knackered sorry u cant just replace it it takes the slip ring it runs on out as well get a recon fella
Old May 3, 2009 | 04:03 PM
They are normally extremely reliable, but this is just bad luck.
I had to do the auto starter on my dads mondy every few years, as it packed up, so now covered it in a plastic bag and sealed the edges of components with sealant, the short wire from solenoid to motor was soaking up moisture, but since this 3 years on and all is well!!
Rob Wells
Ford Mondeo Including ST
Apr 18, 2023 12:19 AM
Dr. Ickxs
Sep 15, 2015 10:15 PM
The Enigma
Sep 12, 2015 10:12 PM
fuzzy
Sep 4, 2015 10:11 PM
