Focus 1.8 engine shaking HELP!
Old Apr 30, 2009 | 03:51 PM
Nath333's Avatar
Nath333
Question Focus 1.8 engine shaking HELP!
I have a 1.8 zetec petrol with k&n 57i induction kit.
The engine shakes alot while idle and when driving it judders and seems to have lost some power.
I have replaced the MAF with one from a mondeo 2.0 zetec and replaced the spark plugs but hasn't worked.
Any help would be appreciated.
Old Apr 30, 2009 | 04:01 PM
Mike Kerbey's Avatar
Mike Kerbey
could be a dodgy coil pack mate
Old May 4, 2009 | 10:42 PM
Nath333's Avatar
Nath333
I was told todat that because i always run the pertrol really low it could be letting crap into the petrol filter and blocking it.
Anyone know if its possible to take it out and clean it?
Old May 4, 2009 | 10:48 PM
pani_k's Avatar
pani_k
PassionFORD Member
Fuel filters are a few quid mate just get rid and stick a new one in. As said above could possible be coil pack or possibly one of the leads not firing properly.
Old May 4, 2009 | 11:03 PM
Nath333's Avatar
Nath333
Cheers mate i'll give it a go tomorrow.
i changed the coil pack made no difference
Old May 4, 2009 | 11:12 PM
G420 DEL's Avatar
G420 DEL
should you be useing the 2.0 maf on your 1.8?
Old May 4, 2009 | 11:14 PM
Nath333's Avatar
Nath333
well with the one i had in the engine was cutting out when i had the maf sensor plugged in but when i put the other one on it stopped it. the part number is the same so i assume its ok
Old May 5, 2009 | 06:14 AM
delterflier's Avatar
delterflier
my focus was running slugish for ages and she was always on the empty
changed the filter and only made a small diference,mines a 1.8 too and to change the filter you have to drop the exhaust and the tank to get to it
pain in the ass.
considering im on empty most of the time there wasnt much crap in the old filters,next to check is the injectors
john
Old May 5, 2009 | 08:40 AM
Nath333's Avatar
Nath333
i think i should check it anyway considering its never been changed and its done over 117k. If that doesn't work think i'll be on to the injectors next too
Old May 5, 2009 | 09:31 AM
pani_k's Avatar
pani_k
PassionFORD Member
pain in the ass.
john
You what mate?
You don't need to drop nothing to get to the fuel filter. If you can get the car up on a ramp its pretty easy.
Old May 5, 2009 | 12:32 PM
martysmartie's Avatar
martysmartie
As said coil packs are known to fail on these as do Renaults, this would describe the shaking as you are running on three cylinders.
Old May 5, 2009 | 04:31 PM
delterflier
Originally Posted by pani_k
You what mate?
i cudnt get my hands in to undo the tenmill nut holding the filter so had to drop the tank but to do that had to release the exhaust from the rubers
Old May 5, 2009 | 07:18 PM
syndicate777's Avatar
syndicate777
you could have a leak at in the inlet manifold or in one of the vacuum hoses. its easiest to just remove it renew the seals and use a good sealant when you put it all back on.
another thing to try would be to use a short section of silicon hose between the filter and the MAF to increase the distance between the two. My 2 litre had a similar problem when i fitted a BMC. Turned out that the filter was creating too much turbulence and 'confusing' the MAF. After I increased the distance between the two points problem gone.
As a point of precaution just check you tightened everything back together to make sure you havnt got any leaks in the system.
Hope this Helps
Old May 8, 2009 | 11:27 PM
Nath333's Avatar
Nath333
Stuff it i'v tried everything and its still doing it.
getting rid of it and buying a Celica GT
Old May 9, 2009 | 01:20 AM
pani_k's Avatar
pani_k
PassionFORD Member
Other thing you could try mate if you haven't is to check the PCV valve and the pipework. Known to cause a sap in power and cause erratic/low idling. Check to see if the pipe is split and/or collapsing under load and also the valve itself. There is also the ISCV valve. Other thing it could be is a blocked exhaust/knackered cat.
RUBY123
Oct 22, 2023 12:04 PM
salsheikh
Ford Focus ST Parts for Sale
Oct 6, 2019 07:56 PM
salsheikh
Ford Focus RS Parts for Sale.
Aug 20, 2015 12:22 PM
coozer
Ford Focus Range
Aug 15, 2015 10:26 PM
taylora1409
Aug 12, 2015 12:06 PM
