Engine Rebuild - Crank
Old Apr 29, 2009 | 07:21 PM
youngben's Avatar
youngben
Default Engine Rebuild - Crank
how tight should the crank be to turn once it is put in and the main caps are tight but no pistons or rods? it seems to turn then stick then turn freely again! have no flyweel on so this may exaggerate the stiffness as i havent much to grip!
Old Apr 29, 2009 | 07:43 PM
cossiedan1983's Avatar
cossiedan1983
there shouldnt be any tight spots really, try loosen caps off and re tighten but turn crank after every cap has been tightened and dont forget to lubricate caps as they go on
Old Apr 29, 2009 | 07:52 PM
youngben's Avatar
youngben
yeh everything was lubricated! it was fine until i tightened them up! will have a closer look tomorrow! didnt think it seemed right! thanks for the tip mate! its loose if you keep moving it and spins fine! its when you stop and try and move it again
Old Apr 29, 2009 | 08:44 PM
Toe Knee's Avatar
Toe Knee
As said should spin freely mate without the flywheel, mine turns by hand on the stand just using the crank pulley and thats with the pistons in and connected too!!
Are they new shells?! and are they deff the right size?! only other thing it could be obviously is damaged journal or to the crank...
Old Apr 29, 2009 | 09:44 PM
youngben's Avatar
youngben
just had a play and its running sweet now spins freely
thanks for your help all! thought it wasn't right
Old Apr 30, 2009 | 12:31 AM
Red16's Avatar
Red16
Some of those main bearing caps are on the wrong way round... all the arrows should point the same direction, usually away from the flywheel, also they should be in numerical order too eg 1, 2, 3, 4, 5
Old Apr 30, 2009 | 12:33 AM
Chip's Avatar
Chip
*** Sierra RS Custard ***
If it was tight in spots and is now loose then I would take it out again and inspect the bearings, there may be a sharp spot on the crank on one of the journals that has scored a bearing.
After all, something has changed!
Old Apr 30, 2009 | 04:18 AM
youngben's Avatar
youngben
thats exactly as they came off mate and how they were put on at the factory
heres a pic of when i stripped the engine
and now
Old Apr 30, 2009 | 01:43 PM
Red16's Avatar
Red16
Just because thats the way they were removed doesnt necessarily mean thats the correct way.
Old Apr 30, 2009 | 02:51 PM
coswurv's Avatar
coswurv
yeah the far right one is facing the wrong way, well going by the arrows it is !
Old Apr 30, 2009 | 03:15 PM
JonnyBravo's Avatar
JonnyBravo
I very much doubt they were meant to be fitted all the same way bar one by the factory.
Find yourself a picture or speak to your usual engine builder as I am sure they could clarify that for you.
Old Apr 30, 2009 | 04:20 PM
youngben's Avatar
youngben
its the 1st time the engine has been apart from the factory so must have been done it differently? it is also numbered 1 2 3 4 1 will try and find more pictures! but they wont fit any other way as they have a recess to fit in anyway! it spins fine now
Old Apr 30, 2009 | 04:30 PM
.Ross.'s Avatar
.Ross.
Did you offered the shells into the cap's/block dry?
Anyhow .. If it's spinning free then "Bingo"
Old Apr 30, 2009 | 04:34 PM
Big Will_'s Avatar
Big Will_
Borg Warner EFR Equipped!
From: In the unit, building a 450bhp Time Attack Focus!
I see you're on ARP Main studs mate...
1) Did you use the moly lube as i can't see any on there and it's critical to get the correct stretch in relation to the listed torque figures.
2) Have you tried the intermediate section of the sump on there yet as i had to die grind clearance channels out of mine to clear the stud!
Old Apr 30, 2009 | 04:41 PM
youngben's Avatar
youngben
no mate they have all been oiled
yes mate used the lube you can see it all over the nutts on the second pic no mate not tryed the sump on yet but i will have the same problem you did
Old Apr 30, 2009 | 04:51 PM
youngben's Avatar
youngben
2 other rs engines with the main caps as stated 1 - 5 so got knows why mine has another 1 on the end instead of number 5 but it don't seem to be causing any problems with the crank movement?
manuel boeckx
13
Oct 3, 2015 02:29 PM
JoeyBoyden
14
Aug 15, 2015 09:51 PM
track.focus'd
Aug 12, 2015 05:53 PM
Zoggon
Aug 10, 2015 10:39 AM
lockie
Jul 31, 2015 10:03 PM
