ERST Cossie Management issue
Old Apr 28, 2009 | 05:49 PM
Zetecfiesta's Avatar
Zetecfiesta
Default ERST Cossie Management issue
ive got cossie management on my Escort turbo, i had it set up and was running perfect on a converted loom, ive just got my own 2wd loom and its running rough as hell, ive checked that every plug is in the right place, ive swaped the wires around on tps and bottom crank sensor, its sparking correctly and the injectors are pulsing but appears that injector 1 and 4 are massivly overfueling, the plugs were wet and it seemed to be seaping from the top of the exhaust manifold whilst running?! anybody got any ideas? im extremly sick of the sodding car at the minute, might give up and flick matches at it till it burns.
Cheers!
Old Apr 28, 2009 | 06:38 PM
Gadget's Avatar
Gadget
Spanner monkey
whats your e mail address? i'll send you an engine loom wiring diagram so you can check from the ecu plug to each pin!
Old Apr 28, 2009 | 07:19 PM
muz's Avatar
muz
Wye Valley Hardcore
I didn't think you needed to swap any wires around on the TPS just the CPS?
Old Apr 28, 2009 | 07:31 PM
Zetecfiesta
think jano told me i had to?!
Old Apr 28, 2009 | 08:26 PM
muz's Avatar
muz
Wye Valley Hardcore
The TPS wires on mine haven't been touched. Give him a ring.
Old Apr 28, 2009 | 09:19 PM
Zetecfiesta
i think we swapped em then swapped em bk depends on if you have a pf09 tps?!
Old Apr 28, 2009 | 10:04 PM
morph's Avatar
morph
will it be too much to put the converted loom back in place to make sure its not the 2wd loom thats faulty or is that going to be a headache? this will probably be the only way to make sure its not the loom or something else.
Old Apr 28, 2009 | 10:19 PM
Zetecfiesta
the converted loom was jano's and he is in essex and im in manc! :-(
Old Apr 29, 2009 | 08:05 AM
cressy's Avatar
cressy
have a word with gadget mate
Old Apr 29, 2009 | 12:59 PM
Daveysaff's Avatar
Daveysaff
Skint Passionford User
As said, Phone Jano or get the diagram Gadgets offered you
Old Apr 29, 2009 | 03:27 PM
JokerDisco's Avatar
JokerDisco
You only need to swap the wires around on the TPS if your using a 4wd TPS with a L8 or P8. Have you checked the gaps on your phase and crank sensor?
Old Apr 29, 2009 | 04:27 PM
Jay-A's Avatar
Jay-A
Break it and sell me the bits, lol !!!!
Old Apr 29, 2009 | 04:52 PM
Zetecfiesta
which 1 is a 4wd tps? ive got a brand new pf09 on mine, jano said the gaps are 6 to 8 thou, ive used my feeler gauges at 0.06 is this correct?
Jay: sod off lol i might be stressing out with it but im gonna have to sort it or its gonna kill me and no way am i gonna end up in a boggo standard car coz i will be bored to death.
Old Apr 29, 2009 | 05:05 PM
Zetecfiesta
phoned jano and spoken to him a million times, think he is a little sick of speaking to me tbh lol ive got those digrams from gadget and looked through them.
Old Apr 29, 2009 | 08:02 PM
O.K.C's Avatar
O.K.C
Eruption 101.3fm
Sam i have the same setup as you and my TPS wires do need to be switched due to the pectel board you have in the ECU.
Also the CPS wires will need to be reversed due to the polarity of the sensor.
Map sensor wires shouldnt be cut for any reason if you can help it!
Other than that all the wires are the same for a 2wd or a 4x4. So if you have fitted a loom to your car and its not working either the loom you have fitted has issues. Or the sensors and components on your engine bay are faulty or not plugged in to the correct plugs or out of adjustment etc. Check the gap settings on each trigger.
Best bet is take it back to jano's and get him to install a loom for you to save you the hassle you have had for so long with secondhand wiring looms.
See you there Danny.
Old Apr 30, 2009 | 09:11 AM
Zetecfiesta
stress now over, give car back to jano and let him fix it lol, im out of time to get it sorted just want a working car!
Old Apr 30, 2009 | 10:33 AM
morph's Avatar
morph
Due to the distance you are, if you have not taken your car down to Jano's yet. why dont you ask him to send you another loom to try? if that doesn't solve the problem then have the car taken down there.
Old Apr 30, 2009 | 12:41 PM
Jay-A's Avatar
Jay-A
haha, am only joking buddy, i know how much work & money you've put into the car u deserve to get it running right and enjoy it!!
Old May 2, 2009 | 04:45 PM
Zetecfiesta
distance aint too bad as i aint doing the driving and ive got some really good mates who will lend me a flatbed and will do the driving for me!
cheers jay!
landaqmabba
Sep 15, 2015 07:16 PM
BRAM
Sep 8, 2015 07:11 AM
Thanasis
Sep 7, 2015 07:33 PM
fordjames
Ford Focus Diesel
Sep 3, 2015 10:20 PM
