ST170 Spacers..
Old Apr 27, 2009 | 07:52 PM
LewisST170's Avatar
LewisST170
Default ST170 Spacers..
Got some 12.5mm wheel spacers for the rear, as the standard wheels look a lil lost in the arch..having slight second thoughts.
Is it worth putting them on or sticking on ebay?
Also hoping to do at least a 20mm Eibach drop or 30/35mm drop if i can find the springs.
Any advice/opinions
Thanks
Old Apr 28, 2009 | 12:08 PM
Sp3no's Avatar
Sp3no
Eibach springs are the best you can get, unfortunately the arse end of the ST170 sits high even when lowered on any springs. My advice is to import the american ST170 Eibach Sportline spings that lower the front 20mm and rear 35mm, so the car sits totally level
You dont need the spacers, there is no real benefit
Old Apr 28, 2009 | 12:23 PM
percybigun's Avatar
percybigun
Twistin me melon man
spacers will make the wheels fill the arch better and give you a wider track
you might need longer studs for 12.5mm spacers though.
Old Apr 28, 2009 | 04:09 PM
LewisST170's Avatar
LewisST170
Yeah, I had eibach springs on my last 170 and agree the back was still very high, but I will look out for the US version sounds a good option.
The spacers are a ford part were used on the FRP, they fit behind the hub so the offset of the wheel doesn't change.
Apparently they will 'improve' handling, what you reckon? noticeable difference in handling?
Thanks
Old Apr 28, 2009 | 06:15 PM
RichieST's Avatar
RichieST
Thanks
I think to be honest it will make it handle worse, the front track will still be the same however the rear will be wider. Cant see the point in it to be honest, they handle very very well as standard!
Old Apr 28, 2009 | 07:27 PM
focusrsred's Avatar
focusrsred
most fwd cars run a wider track at the front. It's to help reduce the lift off oversteer. As standard the focus runs a lot of rake in the geometry, making lift off oversteer more of an issue, so it wouldn't be adviseable from a handling point of view to increase the rear track. Would look better though!
Old Apr 28, 2009 | 08:01 PM
LewisST170's Avatar
LewisST170
Thanks fpr the replies.....ebay they head!!!
Why don't eibach do the Sportline kit for any Ford?? I like the sound of how the 20mm front 35mm rear would look.
arkeye
Ford Focus ST
Feb 20, 2016 01:22 PM
Sp3no
Sep 27, 2015 07:23 PM
Marv888
Sep 26, 2015 03:44 PM
Andypandy260
Sep 23, 2015 10:28 PM
pie-face
Sep 15, 2015 10:43 AM
