What are the Limitations of.....
Old Dec 5, 2004 | 09:46 PM
Ryan's Avatar
Ryan
Default What are the Limitations of.....
A Standard Small Turbo Escy Engine.
Is it just the turbo and management?
Or is the head a worse design?
Can someone explain to me please.
Basically would i be able to bolt a bigger turbo on and l8 or S8 and achieve 400bhp?
Or will the head only flow say 330 in standard form?, im aware that when worked it can flow much more, i.e Gaybirds engine or Yums etc etc.
I take it these engines themselves are pretty good though?
Old Dec 5, 2004 | 09:48 PM
AJ Escos's Avatar
AJ Escos
i beleive they are the best engine as a base to start from but its just the management that holds you back, change management and the sky is the limit as they say (or maybe just your wallet is the limit )
Old Dec 5, 2004 | 09:53 PM
Not sure if it will flow 300 in standard form LOL.....
Old Dec 5, 2004 | 10:05 PM
Ryan's Avatar
Ryan
care to explain dingle?
anyone else care to have an input?
Old Dec 5, 2004 | 10:09 PM
AJ Escos's Avatar
AJ Escos
cant see how the head wouldnt flow enough for 300bhp m8, unless he means the ancilliaries that would obviously need changing, fuel pump injectors etc
Old Dec 5, 2004 | 11:23 PM
Stavros's Avatar
Stavros
DEYTUKURJERBS
Why on earth isnt the head good enough for 300bhp?
Std turbo etc is shite, but purely the engine (ie block/head and everything inside it), itd decent
Old Dec 5, 2004 | 11:27 PM
Ginge !'s Avatar
Ginge !
just finding my feet
the heads are the best heads to work i was always told
but then standard i can understand as they wasnt built for more bhp, was built to be drivable and a decent flowed head can make alittle more lag
Old Dec 6, 2004 | 12:05 AM
Rick's Avatar
Rick
Nothing woring with the management, infact it's far better than the marelli - it just needs someone from blackpool to sort it out.... Turbo is a very good one, but isnt designed for over 300hp.
SMILER258
Sep 28, 2015 09:04 AM
Alloy wheels and ICE for sale
Sep 19, 2015 07:50 PM
Topjoe9
Sep 12, 2015 09:50 AM
Si B
Sep 12, 2015 06:49 AM
