Sapph 4x4 breating issues
Old Feb 25, 2004 | 12:59 PM
IOMwill's Avatar
IOMwill
Default Sapph 4x4 breating issues
Hello all, sapph 4x4 fsh 64k, the lad i sold her to had the turbo fail and now she's running on 3cyls, all have spark and all injectors appear to be pumping ok, he say's there is quite alot of "smoke" coming from the engine breather that connects to airbox is this normal??
Cheers.
Will.
Old Feb 25, 2004 | 06:30 PM
piston gone maybe??
Old Feb 28, 2004 | 01:20 PM
sounds like somits melted!
if it were mine i would have the head off
how did the fault appear?
Old Feb 28, 2004 | 05:46 PM
Tony Ryan's Avatar
Tony Ryan
If the turbo has failed as you say , the chances are that its pumping "boosted " air into the crankcase past the seals in the turbo !
This is probably why its breathing heavily , and possibly why its only on 3 cyls .
get the turbo changed and see if it cures it !
Old Feb 28, 2004 | 06:00 PM
PJay's Avatar
PJay
Piston? Melted? bit drastic advice there guys, i'll go with tony, change the turbo and run it and go from there
Old Mar 1, 2004 | 07:48 PM
HI,mate,
Sounds like piston, compression problem and causing crankcase pressure building up in sump, do a compression test to check and if down, have the injectors flow checked to see if any are suspect ie cylinder running weak, or over boosting, setup problem , sort problem before it happens again after repair,
Dave,
DixieTheKid
11
Jun 6, 2020 11:20 AM
Mark_
14
Jan 16, 2016 05:27 PM
SMILER258
Sep 28, 2015 09:04 AM
mpilk
Sep 27, 2015 09:21 AM
pabloXR
Sep 21, 2015 12:42 PM
