blank dvd's - whats the differance between.......
Old Dec 5, 2004 | 06:33 PM
Graceland's Avatar
Graceland
Team HOTHOT!
Default blank dvd's - whats the differance between.......
DVD "-" and DVD "+" for blank dvd's?
my drive does both, but whats the differance?
Old Dec 5, 2004 | 07:27 PM
Ish's Avatar
Ish
"DVD-R and DVD-RW
DVD-R was the first DVD recording format released that was compatible with standalone DVD Players.
DVD-R is a non-rewriteable format and it is compatible with about 93% of all DVD Players and most DVD-ROMs.
DVD-RW is a rewriteable format and it is compatible with about 80% of all DVD Players and most DVD-ROMs.
DVD-R and DVD-RW supports single side 4.37 computer GB* DVDs(called DVD-5) and double sided 8.75 computer GB* DVDs(called DVD-10).
These formats are supported by DVDForum."
"DVD+R and DVD+RW
DVD+R is a non-rewritable format and it is compatible with about 89% of all DVD Players and most DVD-ROMs.
DVD+RW is a rewritable format and is compatible with about 79% of all DVD Players and most DVD-ROMs.
DVD+R and DVD+RW supports single side 4.37 computer GB* DVDs(called DVD-5) and double side 8.75 computer GB* DVDs(called DVD-10).
These formats are supported by the DVD+RW Alliance."
Old Dec 5, 2004 | 07:31 PM
Graceland's Avatar
Graceland
Team HOTHOT!
cheers ish
which ones the best tho? my comperical knowlege is shite
Old Dec 5, 2004 | 07:34 PM
Eagle's Avatar
Eagle
Super Moderator
so ... in my laymans terms ... not alot of difference then
Old Dec 5, 2004 | 07:47 PM
Ish's Avatar
Ish
i use dvd-r as they cheaper and seem to be more compatible with my ps2/xbox & dvd players
Old Dec 5, 2004 | 08:38 PM
Graceland's Avatar
Graceland
Team HOTHOT!
cheers m8y
Old Dec 5, 2004 | 08:46 PM
AlexF's Avatar
AlexF
which works with ps2?
alex
Old Dec 5, 2004 | 08:49 PM
James Raby's Avatar
James Raby
dvd-r as Ish said above, I use DVD-R discs too
Old Dec 5, 2004 | 08:50 PM
Ish's Avatar
Ish
alex
dvd-r is better for using with a ps2
Old Dec 5, 2004 | 09:21 PM
AlexF's Avatar
AlexF
cheers
alex
Old Dec 5, 2004 | 10:23 PM
EvilFranky's Avatar
EvilFranky
Ritek dye
Old Dec 5, 2004 | 10:26 PM
Jim Galbally's Avatar
Jim Galbally
i personally use DVD-R
as per franky tho, get disks using the ritek dye!
4x seem to be the cheapest but if youve got an 8x drive its worth spending the extra mney for the 8x discs... as it saves a fair old amount of tikme when burning them!
wowk
Mar 30, 2021 07:49 PM
Daniel Howard
Ford Classics & Vintage
Oct 3, 2015 10:44 PM
SMILER258
Sep 28, 2015 09:04 AM
Sp3no
Sep 27, 2015 07:23 PM
little bram
Sep 27, 2015 07:45 AM
