zetec turbo boost problem
as in title... it drives fine but as soon as it comes on boost it missfires, pops and bangs sometimes it boosts fine. ive changed the plugs then checked them after a drive and one of them goes a bit white on the end which i beleive is due to running lean and the rest are wet. anyone know what it could be?
which plugs and leads you running ?
try running the car on some rs focus plugs as they run slightly cooler than std zetec ones
would check leads and coil pack to for faults.
the car would benfit from running on super unleaded to cut the risk of melting something.
As for it doing it at half tank would check the pressure on the fuel pump and fuel reg as it could be just a earthing problem or the pump not man enough for the job
would also check to see if it is running right and have the set up checked
Or could be the usual Walbro 255 problem when used to replace standard Ford intank pump. Has quite a high pickup as it has a built in filter. Well know issue for example on FRS - either never run less than 1/4 tank or, standard pump to external swirl pot or, use a 'blue' or 'green' top pump.
Martin
Martin
Billy_RS
16
Oct 11, 2025 09:41 PM
