mot failed
Old Apr 25, 2009 | 03:09 PM
ROB7656's Avatar
ROB7656
Default mot failed
my s2 failed on emmisions the tester showed me on his chart that it should be 0.5 and mine is 6.0 i explained to him that i had paid alot of money to have the fueling set etc and he said that to pass he needed to adjust it. obviously i dont want it messing with just wondered if you lot think 6.0 is to rich ??? my tuner obviously doesent
Old Apr 25, 2009 | 03:10 PM
ROB7656's Avatar
ROB7656
forgot to ad the car is running standard boost
Old Apr 25, 2009 | 03:11 PM
RichieST's Avatar
RichieST
Your obviously using the wrong tuner......
Old Apr 25, 2009 | 03:19 PM
coco16i's Avatar
coco16i
If its an RS Turbo escort the emission limits for it will be 3.5 max so the limit of 0.5 he told you it should have been is wrong !
And if the reading was 6.0 its running way too rich, especially if you have just paid to have it tuned !
Old Apr 25, 2009 | 03:21 PM
ROB7656's Avatar
ROB7656
maybe but he has a good rep and a few magazine featured cvh turbo cars have been built tuned by him. and before anyone says it wasent tuned by engine advantages
Old Apr 25, 2009 | 03:23 PM
ROB7656's Avatar
ROB7656
was tune 4k miles ago so maybe out of tune i suppose with the good old metering head
Old Apr 26, 2009 | 05:10 AM
ROB7656's Avatar
ROB7656
Old Apr 26, 2009 | 11:23 AM
orion_crazy_carl's Avatar
orion_crazy_carl
orion=mini saff
with std boost u can safely turn it down to well under the 3.5 it should be under
Old Apr 26, 2009 | 11:58 AM
j6kyt's Avatar
j6kyt
I bet your idle screw is almost hanging out running 6%co I used to run my old s2 at 3% and i checked it regularly as they go off quickly. I was running 18lbs boost and it was fine.
Old Apr 26, 2009 | 05:45 PM
ROB7656's Avatar
ROB7656
i just wondered if it was rich at idle because of the crude mfi fuelling on boost? so if i dropped idle down would it drop co?
Old Apr 26, 2009 | 05:53 PM
j6kyt's Avatar
j6kyt
It needs setting at the metering head. Then reset the idle.
Old Apr 26, 2009 | 06:00 PM
SillyFezzaMk1's Avatar
SillyFezzaMk1
Rubber Rhino Crew
I wouldnt trust the reading of 6%, he obviously wants to charge you for the setting of co2 so tell him to fuck off & take it somewhere else.
If your tuner has set it right then it will pass mot, looks to me the mot guy just wants to squeeze some ££ out of you.
Plus your tuner wont want to know if its been messed with.
Dan
Old Apr 26, 2009 | 06:59 PM
©hatter Box's Avatar
©hatter Box
mark at grove does mots
Old Apr 26, 2009 | 07:09 PM
mad dog younge's Avatar
mad dog younge
like coco16i said .the limit for your s2 is 3.5 ,so it should of passed .i can get mots done and that wont fail .
Old Apr 26, 2009 | 07:18 PM
The Youth.'s Avatar
The Youth.
youngie his co was 6.0 the limit is 3.5 so it should have failed!
think you read it wrong..
steve
Old Apr 26, 2009 | 07:22 PM
ROB7656's Avatar
ROB7656
guys not trying to rob me. he said he would set it to pass then reset to6.0 if thats what i want. the car runs sweet as but obviously from the replies its too rich will speak to my tuner monday. he is a ex boreham rs tech of 22 years so trust him as much as any tuner about. maybe my mettering head has thrown a wobbly.
Old Apr 26, 2009 | 09:46 PM
orionmojo's Avatar
orionmojo
dont let him touch it. if its been set by a tuner and it runs well then leave it. if he's willing to fiddle the test to put it back after then he'll be willing to just use another car on the ramp for that part of the test.
Old Apr 27, 2009 | 07:01 AM
G950KDT's Avatar
G950KDT
as above really, if your tuner has set it at a set rate and has that many years experiancei think he will know what hes doing. dont let the MOT guy touch it, take it to the tuner you had the work done with and get him to check co rating if your unsure, if it comes back the guy was taking the piss at the mot, then dont go back and go to another garage that specialises in escort RS's
Old Apr 27, 2009 | 02:47 PM
ROB7656's Avatar
ROB7656
spoke to the tuner and he told me it was set 3.47 so the car is now set to 3.5 co and has an mot. how it was that far out is beyond me and i never tamper with it so the good old mfi strikes again.will be going back to the tuner soon if i decide to chip it
Nov 1, 2015 06:53 PM
gcfcos
59
Oct 6, 2015 05:04 PM
SMILER258
Sep 28, 2015 09:04 AM
