Numbers on top of pistons
Old Dec 5, 2004 | 03:21 PM
GAZ W's Avatar
GAZ W
Default Numbers on top of pistons
Can you tell me what these numbers mean on top of my pistons
18755 + 2.25mm
93.045c
spo.025
20HC
N43I.D.1
CHEERS
Old Dec 5, 2004 | 04:16 PM
scruffythefirst's Avatar
scruffythefirst
20hc - 2litre high compression
93.045c - piston size (grade c) (might be bore size)
spo .025 -.025 oversize ?
Maybe
what engine is it?
Old Dec 5, 2004 | 04:30 PM
GAZ W's Avatar
GAZ W
Its a 2.0L pinto that i was told was now a 2.1 ,s o what you said there seems about right
Old Dec 5, 2004 | 07:00 PM
Matt's Avatar
Matt
why is the head off pal?
Old Dec 5, 2004 | 07:47 PM
GAZ W's Avatar
GAZ W
I took it off around 4 months ago wanting some work doing to it by karl , but since its been of he's been busy but says he should be able to start work on it around january
James Porter
Oct 28, 2015 12:17 PM
KW-rscos
11
Aug 31, 2015 01:51 PM
Escortdriver1
Aug 31, 2015 11:19 AM
ekjim
Aug 17, 2015 08:57 PM
Roosie
Aug 13, 2015 07:40 PM
