Cruise control Mondeo/Focus
Old Apr 23, 2009 | 05:40 PM
Shonky's Avatar
Shonky
V6 Ka of Love
Default Cruise control Mondeo/Focus
Does anyone know if the mondeo or focus' cruise control needs a speed signal? I'm looking to retro fit cruise control to my Ka, I know a Vauxhall CC will not work without a speed signal, does the Ford CC need it? Does anyone know of a system (don't care about the manufacturer) that has a setup that does not require a speed signal and have a wiring diagram for and is freely available? (read cheap!)
Old Apr 23, 2009 | 06:04 PM
Pretty sure the ford CC does need a signal, but what's the problem as you have one on your ka anyway ?
Old Apr 23, 2009 | 06:11 PM
Shonky's Avatar
Shonky
V6 Ka of Love
I have Vauxhall engine in the Ka, I can't get a VSS from the Vauxhall setup as it's generated with parts I couldn't use on the conversion, the Vauxhall VSS needs a speed signal too
I have an aftermarket VSS for a digi dash, I was thinking about trying that but don't want to waste the cash if someone knew of a more suitable setup
Old Apr 24, 2009 | 05:39 PM
The std KA outputs a VSS via the hub, for the std ecu, so unless this has been taken off use that.
Old Apr 26, 2009 | 01:09 PM
Shonky's Avatar
Shonky
V6 Ka of Love
I didn't have ABS on it originally, I'm assuming much like vauxhall the ABS ECU will send a signal out to the clocks and cruise control not get it directly from the wheel speed sensor so I'd have to plumb in the ABS system, I might park this for a bit, I'll finish some other bits first
Old Apr 26, 2009 | 04:25 PM
The VSS is used in IDLE control, so is present on all KA's, it raises the idle speed if coasting, so just coast along at say 30mph in neutral and see if this causes the idel speed to stay high, around 1200/1400, if it does, then drops as you stop then you know it is getting a signal.
Old Apr 26, 2009 | 05:06 PM
Shonky's Avatar
Shonky
V6 Ka of Love
I have Vauxhall engine and gearbox in my ka (with an aftermarket speedo pickup) so I wont be able to test it using the idle control method unfortunately as I see it I have a few options
1) Use the Vauxhall cruise control unit (as I have the wiring pinouts) and try the aftermarket wheelspeed sensor
2) retro fit ABS on the Ka and to get a VSS for a mondeo cruise control unit
3) Get any cruise control unit and control the motor directly bypassing the need for a VSS
4) Use an aftermarket cruise control unit
5) don't bother with the cruise control!
mark94
Ford Mondeo Including ST
Oct 10, 2023 06:52 PM
Tank Mike
Ford Focus Diesel
Feb 23, 2022 06:09 PM
fordrallycar
Sep 30, 2015 07:57 PM
stevecfrst1
Sep 30, 2015 05:18 AM
