warning light on dash
As mentioned ABS, just to point out my stays on, but only because one of the belt had snapped, if you leave the car how it is it will fail the MOT, my way round this has been to remove the bulb for the dash light, i have never had any problems driving with the ABS belt snapped, and even taking the belt out is not accepted in some MOT Stations some over look it.
you could go down the long route and remove the whole ABS unit. the belt is only about £10, but you need to remove the shield etc to fit it.
you can fail for abs lamp not coming on, abs lamp indicating a fault on the system or abs lamp does not follow correct sequence
so if your only bothered about passing the mot join the 2 wires that go to the belttension sensors so the light will function as normal
nipper.1
Ford KUGA
12
May 30, 2022 07:39 PM
Dr. Ickxs
Sep 15, 2015 10:15 PM
The Enigma
Sep 12, 2015 10:12 PM
