S2 ERST running / starting problems
Old Apr 19, 2009 | 07:24 PM
RSTurboSI's Avatar
RSTurboSI
Default S2 ERST running / starting problems
Ok here goes.
Cars Been running fine, no miss fire or problems.
Today as it was nice went and washed the car, started the car and ran it, running fine. Again no miss fire or problem, So i washed down the engine bay as there was some oil in parts and it was dirty, all ok. Ran it for a while and was fine.. Went and turned it off, right after checked that it started and it was fine.. now i turned it off for a while and started it again, started with a miss fire, so i taken the plugs out one by one still problems, then taken them off one by one on the dissy and cleaned them, now it wont start at all...
idears?
Old Apr 19, 2009 | 07:37 PM
studabear's Avatar
studabear
water inside the distributor cap perhaps
Old Apr 19, 2009 | 09:59 PM
bad boy's Avatar
bad boy
dont get too disheartned si, it will be something simple. We checked everything best we could just give it time to dry out and hopefully 2moz it will go.
Old Apr 19, 2009 | 10:44 PM
RSandy's Avatar
RSandy
yup, id have a check of the dizzy cap and rotor arm for any moisture thats built up in there from cleaning. dry it out, bit of WD40 to clean it up, refit and try again dude
does sound like something saft like this anyways
Old Apr 19, 2009 | 10:58 PM
Chopshop85's Avatar
Chopshop85
yeah i had the same problem after cleaning my engine bay.
Was a bit of moisture inside the sensor that sits ontop od the dizzy as they are never a snug fit.
Old Apr 20, 2009 | 12:54 PM
RSTurboSI's Avatar
RSTurboSI
will give it ago with some WD40 and try dry them out...
Old Apr 20, 2009 | 07:50 PM
RSTurboSI's Avatar
RSTurboSI
so update :
Had to remove all spark plugs, aswell as HTleads. I had them on the line over today and bonnets been off to try dry anything thats left over that maybe wet.
I removed most parts so the engine was bear and cleaned and dryed, now replaced everything and went to replace the HTleads, 1-3-4-2 was what it said in my book, for some reasson it still wont start.
i cant see anything thats still wet and removed most components that make the car run, I know the fuel pump is working as there is fuel going in, Also i know there is spark within the HTleads, again removed the plugs and started it with someone there to tell me if its sparking, repeated this on all 4 plugsleads.
now removed the plugs and they was a fair amount not alot of fuel on the spark plug. from my view that sounds like its fluded.. How can i unflood the system?? without moving the car, plus have i got the Firining order right?? 1342
i tryed it on 1324 and it wanted to fire up but didnt... I cant afford to take it into a garage so im trying to sorce info and maybe some kind help..
Old Apr 21, 2009 | 06:07 PM
studabear's Avatar
studabear
1342 is correct according to autodata no 1 lead on you dizzy cap is bottom left if this makes sense then going anti clockwise for the rest.
>>>>>>>>>>>>>>> 24
leads should look like this 13
if the cylinders are flooded prob best way I can suggest to unflood is leave the spark plugs out for a few hours hopefully the excess fuel will evaporate
Old Apr 21, 2009 | 06:10 PM
studabear's Avatar
studabear
1 3
Old Apr 22, 2009 | 01:44 PM
RSTurboSI's Avatar
RSTurboSI
Originally Posted by studabear
2 4
1 3
will make a diagram so you can correct me if im wrong
Old Apr 22, 2009 | 03:59 PM
RSTurboSI's Avatar
RSTurboSI
all done, that above is incorrect....
Old Apr 22, 2009 | 05:14 PM
JamboRS's Avatar
JamboRS
focus rs 1672
top right on that diagram(4) should be 1 then goin anti clockwise 3 4 2
Old Apr 22, 2009 | 05:54 PM
RSTurboSI's Avatar
RSTurboSI
only if you posted sooner
that is correct
Old Apr 22, 2009 | 07:59 PM
studabear's Avatar
studabear
is it running now?
Johnsie
Ford Focus ST
Sep 8, 2015 02:39 PM
nick8saff
Aug 16, 2015 05:35 PM
Zoggon
Aug 10, 2015 10:39 AM
ginger1979
Jul 31, 2015 09:56 PM
