just bought another series 1 not ran it for a week went out to start it and the starter just clicks plenty of battery and started ok untill no but it does have a stupid push button start wired to the starter motor anyone help p.s the starter looks quite new
sound like solenoid wire ,just to eliminate flat battry try it with jump leeds,if not then bridge the push button switch,if not that run a wire direct to the solenoid on the starter
tryed different batterys another starter taken the push button out and fixed the wireing the single wire to the selonoid have voltage when i try to turn it over but still same problem
