2.1 16v turbo conversion
can any 1 help or give some advice,i have this 89 rs turbo with 2.1 16v turbo already fitted there is no ecu or engine wiring loom and have been told that a fiesta rst ofab ecu with frst wiring loom will run it,is this possible or not i have a ofab ecu but no wiring so will it be worth me buying a frst wiring loom or not all help is greatfully recieved
With a 2.1 Zetec a fiesta loom would be rubbish. With that set up you'll want something mappable. I'd recoomend Omex 600 or Emerald ECU, you make up your own loom. Its what i'm doing with my 1.8 ZVH.
a 1600 ECU will probably run lean on this set up, do it right first time with a mappable ECU.
JK12
33
Apr 26, 2021 12:09 PM
