Mk3 fiesta with 1800/2000cc zetec queries
Hi, Just a few queries about the mk3 fiesta..
How much weight can be stripped from a mk3 fiesta roughly?
What are the best brakes to use, what fit and with can be modified to fit?
Is there any off the shelf roll cages that can be bought for the mk3?
Where would we go to find plexi glass windows or something of that sort?
Does anywhere make fibreglass panels for the fiesta or can these be custom made, if so where?
How easy is it to fit a 2ltr duratec?
What is the best exhaust system for the 1800/2ltr zetex, i.e what gives best gains?
How do they react to being de-catted?
Can standard ECU be re-mapped, if not whats the best cheap alternative?
How much of the dashboard can be taken out to save weight?
How much of the eletricals be taken out?
What is a good price for a non running fiesta Si 1.6?
Is there any guides on building a ZVH turbo or a zetec turbo engine?
Is a TDO4 the best turbo to use for such conversions, when only looking for around 200bhp/180whp?
What is the best suspension?
Any buying guides for fiestas as dont want to buy a lemon?
Thanks
Kelly
Thanks
Kelly
u can fit a 2ltr duratic engine in well the best brakes i am not sure about i got a mk5 fiesta with focus st170 brakes on they work well i am hoping to find a 2.1 zvh engine to go in so i am not sure at the moment about what brakes to put in ur mk3 i would go for the 2 litre zetec
[quote=kelly87;4092864]Hi, Just a few queries about the mk3 fiesta..
not sure
What are the best brakes to use, what fit and with can be modified to fit? hi spec do off the shelf kits
custom cages
plastics 4 cars i think it called
smith and dekins
would be alot of hassle stick with the zetec
magnex but personally mongoose
not sure
yes it can be remapped but not for turbo so use fiesta turbo wiring and ecu ofab one
they dont way much to be honest
are you keeping it road legal if you are them you will need most of it
Ł100/200
on zetecturbo.com
t25 or a t3
gaz gold without a doubt without paying Ł2500 a corner
fast ford mag or performance ford
but bad point on the shells are around the filler cap , floor pans , sills , battery tray and wheel arches
hope this helps
not sure
custom cages
smith and dekins
not sure
Ł100/200
on zetecturbo.com
t25 or a t3
hope this helps
TPM961
Jan 15, 2018 10:50 AM
liamT74
Sep 23, 2015 10:24 PM
