Fiesta turbo engines
Old Apr 18, 2009 | 04:55 PM
white2lsr's Avatar
white2lsr
Default Fiesta turbo engines
Are the block/head the same as the ERST?
Old Apr 18, 2009 | 05:07 PM
JonathanJ's Avatar
JonathanJ
No and NO !!!!
FRST is EFI so block has a hole in for crankshaft sensor and head has completely different port shape due to the injector positioning , depends on which way around you are looking to switch block , an EFI block could be used on an MFI engine , but the other way around can cause a bit of a head ache .
Hope this helps BTW use to live in Kendal
Old Apr 18, 2009 | 06:18 PM
studabear's Avatar
studabear
you can get adapter plates for the heads from oddkidd creations
Old Apr 18, 2009 | 07:48 PM
Oranoco's Avatar
Oranoco
The FRST block uses a Crank Position Sensor in it which requires a blanking plate or similar. You need to remove the push fitted oil return as the FRST one (if still on a T2) is of the threaded type which doesn't suit the T3's oil return hose (cost all of 97p from Ford when I changed mine).
Heads are totally different though and not really interchangable without adapter plates as the inlet manifolds and injection systems are different.
JoeyBoyden
Jan 4, 2024 02:36 PM
Kirstiestar
Ford Fiesta
Aug 17, 2015 07:40 AM
Rickyrustyfox
Aug 13, 2015 01:11 PM
knight19770
Aug 4, 2015 12:36 PM
