How to fit S1 arches on a S2
I bought a replica set of S1 arches/wide arches for my S2. I know i need to drill holes to fit it where the originals where screwed in, but i will need some kind of bonding on the outside... hope it make sence
Searching PF i found that some kind of adhensive is use, but what ??
Henrik
Henrik
Hi Ad4m RST
The kit is pre-cut so it should fit. It is not a 100% replica as you can see from the picture on the companys website here
Really wanted a S1 kit, but did not wanted to do all the work cutting it so that it would fit... then found this kit, hopefully it will look almost as nice as the original S1 kit.
fuzzy
21
Feb 15, 2016 10:26 PM
Matt Baxter
Sep 16, 2015 08:30 PM
track.focus'd
Aug 12, 2015 05:53 PM
