how do you take an engine out??
Old Apr 17, 2009 | 07:07 PM
sean_rsts2's Avatar
sean_rsts2
addicted to boost
Default how do you take an engine out??
after tinkerin with my car this afternoon, i have decided to take the engine out, due to find a rust hole! i have thought that i might aswell get it done now and have the engine bay all sprayed up!
im mechanically minded but have never taken the engine out of a car before so gunna give it a go!
was just after tips really on what to do and what not to do. what to do first and what to do last if you get me.
i could probably figure out but need the help of you guys to get the job done properly!!
any help would be immense!
cheers
Old Apr 17, 2009 | 07:10 PM
clarke5700's Avatar
clarke5700
YES I KNOW I CANT SPELL
cheers
if you have to ask i wud not advise it tbh but if you are going to start buy looking around getting a feal for where things are and where they go take sum pics if you like then remove things one at a time and keep all the nuts/bolts/clips with that item ect where abouts are you?
Old Apr 17, 2009 | 07:12 PM
jacko's Avatar
jacko
as above mate cant realy add to that other than be safe doing it there not exactly light
Old Apr 17, 2009 | 07:20 PM
sean_rsts2's Avatar
sean_rsts2
addicted to boost
am in grimsby mate.
got a mate helping me next weekend who knows what he is doing i just wanna get as much done as possible for that weekend as its going in spray shop hopefully
Old Apr 17, 2009 | 07:22 PM
rst in breaking's Avatar
rst in breaking
what car is it in?
Old Apr 17, 2009 | 08:11 PM
mikey_clough's Avatar
mikey_clough
ive just taken mine out, jacked it up and dropped it out the bottom and i seriously advise not to do it that way! thought id save some money and not hire a crane, i regretted that... best way is to take bonnet off and lift engine and gearbox out as one
Old Apr 17, 2009 | 09:05 PM
dangerousbrian's Avatar
dangerousbrian
even better way is to use a engine crane and bring engine and box up from the bottom..have to take bit more off, anti roll bar etc but it saves the risk of scratching the paint where its visible...
Old Apr 17, 2009 | 09:12 PM
Dan1281's Avatar
Dan1281
if you're doing it with limited equipment then a few strong mates, a good plank of wood and some rope soes the trick
tie the engine to the wood with the rope then get a mate/couple of mates either side of the car to lift it out
Old Apr 18, 2009 | 11:15 PM
rstdave's Avatar
rstdave
Engine cranes don't cost that much to hire for the weekend lol!
Old Apr 18, 2009 | 11:25 PM
fullyboosted175's Avatar
fullyboosted175
what car is this for, as this would help alot?
i'm taking it as your mate knows what hes doing he has a host/crane or access to 1, other wise don't do it, it's not safe & if you think it's hard taking it out that way, try putting it back in!
Old Apr 18, 2009 | 11:41 PM
Jimmyc's Avatar
Jimmyc
Dropped mine out the bottom onto an old skateboard and rolled it out.
Nice and simple, just make sure you get it balanced nicely on the board, don't want it tipping over
Old Apr 19, 2009 | 07:27 AM
B_E_N's Avatar
B_E_N
Taken mine out yesterday with my dad, basically stripped the top end, head off etc, then we lifted the block out with a long bar accross the front and sum rope!
Old Apr 19, 2009 | 01:02 PM
delterflier's Avatar
delterflier
i done a engine swap on a astra when the timing belt snaped,was the same as you mechanicly minded but little experiance,all i had was a haynes manual.
deff hire a crain there not expensive,but the main thing ........take your time
if you rush it u wud most likely break somthing and not nessaserily on the car!!
(sorry about the spelling)
john
Old Apr 19, 2009 | 01:25 PM
Alex_86's Avatar
Alex_86
not very hard actually
just undo everything and take it out
hopper350
Sep 4, 2015 12:53 AM
Sep 3, 2015 10:49 AM
