3 Door feul Pump Fuse/Relay
Old Apr 17, 2009 | 04:35 PM
Barry R's Avatar
Barry R
Default 3 Door feul Pump Fuse/Relay
Where are these located I havent got power to pump
Old Apr 17, 2009 | 06:00 PM
On the relay holder above passenger feet at the rear of the glovebox, on a bracket that supports the rear of the dash, there are quite a few there inc abs and fuel pump, the fuel pump is a yellow one with a BLACK/RED wire coming from it as this is the feed out to the pump(through cut off).
I would check the fuel cut off in the boot under spare wheel first to see if it has popped up, if so just depress to reset.
Old Apr 17, 2009 | 06:11 PM
Barry R's Avatar
Barry R
It doesnt have a shut off on mine mate
Basically I have reshelled my 3 door and now the pump doesnt work
Where is the earth for it aswell
Old Apr 17, 2009 | 10:14 PM
costina's Avatar
costina
Live long and prosper!!
Do you have voltage at the pump? cos sometimes the pumps just jam up
Also the 3dr ecu and pump relays are near the ecu both yellow in colour and each have there own fuse
Old Apr 18, 2009 | 08:12 AM
Barry R's Avatar
Barry R
Gonna check it all today mate all I done was turn ign on and no pump noise
Old Apr 18, 2009 | 11:53 AM
Barry R's Avatar
Barry R
Got no power to the pump i pulled the dash out and the relay clicks when i turn ign on
I have a live there and if i put a live to the black with red at the relay the pump goes whats next please help before I scrap the f@@k@@g thing
Old Apr 18, 2009 | 12:19 PM
costina's Avatar
costina
Barry are you sure you have not got a cut off switch?
On a saff that would be the answer power at relay and no power at pump
Just going to look in the bible to see if the 3dr has the switch in a different place
Paul
Old Apr 18, 2009 | 12:23 PM
If it's the fuel pump relay clicking when you turn the ignition on, it shows that the relay is working and being fed, by ecu and live supply.
So we are down to the OUTPUT from the relay, which is on terminal 87, look at relay to see which slot is 87, and when a live is put in that slot does the pump then work ?, if it does renew relay, if it doesn't there is a break in the wire from relay to the fuel pump.
Terminal 30 or 30/51 is the permanent live supply to the relay(not the ecu one), so make sure this is present, use this feed to supply terminal 87, as that is all the relay does join them two together, pump should run.
Old Apr 18, 2009 | 12:27 PM
costina's Avatar
costina
Just looked at book and cannot find that a 3dr had a cut off switch which is very strange
But do as above this should give you some idea
Paul
Old Apr 18, 2009 | 03:25 PM
Barry R's Avatar
Barry R
CheeRS lads ive done it now
Would you beleive 3 relays all shot pinched 1 out of another car and it went
Now all I need to know is what colour wires are for the rad fan switch
jonfoc
16
Sep 11, 2018 05:35 PM
Ford Focus RS Parts for Sale.
Mar 9, 2016 01:03 PM
Nov 5, 2015 08:12 PM
Nov 3, 2015 04:08 PM
Adam Graham
Sep 6, 2015 06:04 AM
