XR3i to rs turbo conversion
Old Apr 17, 2009 | 03:36 PM
xrs_man's Avatar
xrs_man
Default XR3i to rs turbo conversion
hi,
i am converting my mk4 escort xr3i into an efi rs turbo. I have the ofab ecu ect. However the loom that is in the car at the moment doesnt have the plug connection to seperate the engine bay loom from the the rest of it, can i solve this problem easily?
Where the wires come out of the fuse box the injectors, map sensor and co potentiometer go off along the bulkhead and there is the other part of the loom that goes along the drivers wing and along the front which has the lights, indicators on it also has the wiring fr the edis4 module ect, is this normal or is this a dodgy loom?
thanks
Old Apr 19, 2009 | 01:31 PM
xrs_man's Avatar
xrs_man
the fiesta ofab loom plug has the following colour wires going to the pins.
pin 1 - black
pin 2 - brown
pin 3 - green
pin 4 - brown
pin 5 - green & black
pin 6 - green & brown
pin 7 - red
is there a way of wiring this up without the connectin plug to the escort loom?
thanks
JK12
33
Apr 26, 2021 12:09 PM
Matt Baxter
Sep 16, 2015 08:30 PM
kevin36
Sep 2, 2015 06:24 PM
marky_g
Aug 15, 2015 10:43 AM
