Fuse gauges?
Old Dec 4, 2004 | 12:16 PM
ballin's Avatar
ballin
Default Fuse gauges?
do you lot put an inline fuse on your 12V supply to your gauges, oil temp etc?
autometer doesnt mention it and neither do any other sites ive read, but im not sure (electrics aint really my thing!)
if you have, what size, 5amp?
reason i ask, is Mike Rainbirds ACT gauge says you MUST use a fuse....and my autometer electrical gauge says noofin?
anyone clarify?
ta
Old Dec 4, 2004 | 12:19 PM
ECU Monitor Enthusiast
Its always a good idea to put the CORRECT size fuse inline with any
device needing power.
Ideally nearer to the place where the power comes from is best.
OR take power from a circuit that has a low enough amp size fuse protection already.
Old Dec 4, 2004 | 03:42 PM
flashpoint's Avatar
flashpoint
I think that autometer assume that you would take the supply from a fused live
Steve
Old Dec 4, 2004 | 05:29 PM
Jim Galbally's Avatar
Jim Galbally
mine currently aren't... but only coz i've not got round to doin the wiring 110% yet...
theyre coming off of a fused feed anyway, so shouldnt be an issue
Old Dec 4, 2004 | 07:20 PM
ballin's Avatar
ballin
okay cheers for the help, which fused live is best to take from then, cos i dont know what the current the autometer gauge draws??? (oil temp)
i assume wiring it into a 5amp circuit is what you want?
fankyou
(and ta for the PM steve )
Old Dec 4, 2004 | 07:30 PM
flashpoint's Avatar
flashpoint
Hi Rich, for the gauges your using any live feed will be fine, providing its switched by the ignition, I would take a live feed off of the back of the ignition though a fuse and then to your gauges
Steve
Old Dec 4, 2004 | 07:34 PM
ballin's Avatar
ballin
your a legend, ta
Old Dec 4, 2004 | 09:00 PM
Jim Galbally
i personally use the same feed as the stereo, but only as its the easiest one to reach at behind the dash board
altho strangely on my car the stereo shares the same feed as the instrument cluster
but then the wiring on my car is properly donald ducked!
Nov 1, 2015 06:53 PM
Mark RS
Oct 12, 2015 06:01 AM
IainRS1700T
Sep 25, 2015 06:44 AM
wheelwizardrefurbs
Sep 22, 2015 05:45 PM
CrOwSoN15
14
Sep 3, 2015 12:21 PM
