what oil?
hi, my s/t escos is due a service very soon but i cant decide what oil to use? its been run on mobile, shell helix in past, are these ok or are there any others that are recomended such as cosworth, castrol? not sure what viscosity to use either 5/40 5/50? choices choices lol
any help on this would be great cheers.
chris.
chris.
forgot to mention the car has done 23k and it holds about 1.8-2 bar oil pressure when warm but does sound a tiny bit tappety, not sure if this is normal with these engines as its me 1st cossy
. dont know if this info makes any difference to choice of oil?
pro s 10/50 is the oil to use
oil pressure is a subject that normally gets alot of different answers as there are so many variables
if 2 bar is after a long hard thrash then its not that bad a reading, but it really depends on lots of things
votes lol
From: guernsey,c.i.. a rip off island , full of drunks
the engines are not the quietest ... thats correct ... but i would expect more than 1.8 to 2.0 oil pressure ... i have a small turbo and mine between 4.0 and 5.0 bar at about 2000 rpm when warm ... most people recommend a 15/50 weight oil ... i will quote some official ford oil pressure figures .. minimum oil pressure at 900/950 rpm 1.8 bar and at2000 rpm 2.4 bar ...... ps .. those figures are for a 5/50 weight oil at 80 degrees .c. ... i hope this helps ... ps .. mine has done 47000 miles and i use motul 300v 15/50 ...........
From the GGR web site:
OIL PRESSURE (ALL MODELS)
MINIMUM OIL PRESSURE WHEN AT NORMAL OPERATING TEMPERATURE.
IDLE SPEED1.8 BAR (26 PSI)
2000 RPM2.4 BAR (35 PSI)
I wouldn't use 15w50 as its too thick from cold when you need it to be thin, the manual states 5w50, but thats on a new engine. As with most things its trial & error, a noisy engine when cold could be due to the oil being too thin or too thick.
You just have to find what works for yours.
but as most have said there not the quietest enginescheers for everyones views on this
I use motorcraft oil thats what it was designed on and my oil pressure is fine. Also if the car wasn't fitted with a oil pressure guage like most cars you wouldnt take any notice anyway. well unless the pressure light stayed on??
just a word of warning about the standard system on cossies oil pressure warning. The oil light will only come on when the pressure is at 7psi or lower, but which time it might as well say "your engine is fucked". the damage would already have been done at 7psi
seriously? ignorance is bliss!
warning light is a bit useless really so good job they have a guage
, i have went with the pro s 10/50 anyway as it seems to get enough votes so cheers for everyones advice
I had to check the container several times as it just doesn't look right.
deathrider666
Sep 28, 2015 06:12 PM
