Xxxxx gaz coilovers xxxxx
There has been quite a few threads about coilovers in recent months....i've got the gaz gold's so can't really comment on the cheaper ones but i'm not overly impressed with them tbh, amongst other fitting issues etc the zinc coating they put on them is crap, mine aren't that old, the car lives in a garage and they're going rusty already!
i think the no return policy contains 1 important statement, which reads something like:
'You may keep the item sent aslong as you write glowing report about the product, even if you feel that it is only ok, you must not suggest this in anyway, only that the product is - Great, Exceptional, Excellent, Outstanding, the very best, if your unsure of wording then please contact us for suggestions. and as allways please enjoy this product as a gift.'
or something along those lines!
I looked at Gaz but wasn't too impressed with what I saw and what i was told, so was going to go with Koni Adjustables untill some Leda Coilovers came up on eBay. Paid about Ł600 IIRC all in just recon'd and they are far far superiour to the AVO's I had on my previous Fiestas.
That's the problem I have with coilovers I dont really fancy doing that, although given the way that my RS is going (spiralling out of control) I reckon it is inevitable.
got them on mine had to do a bit of seam welding and a rear brace but cant fault them
not had any problems with them well i didnt till it came off the road got to see what there like after they have been stood for a while from what i can see they look ok
Ive got gaz coilovers on mine had all the strengthening done, only drove it for about 300 miles before i took it off the road for other mods they were bang on apart from the coating
got them on mine now too, spoke to gaz themselves and they said the gold kit arnt really suitable for road use as the dampers are too hard so i got the cheaper kit, they fit perfect i specced them with slightly softer springs than they normally come with and the ride is perfect even better with the car corner weighted beats konis in every way the car is now a pleasure to drive and doesnt tourque steer as much anymore i would highly reccomend these for fast road use
People with Gaz coilovers, can you measure what height you have from the ground to the rear arch? Also, would be handy to know how much droop you get when you jack the car up.
Finally, do they knock when you go over bumps?
I'll start......
Gaz Golds - They aren't too hard really.
I have 595mm from the ground to the rear arch
I get very little droop, I haven't measured, but around 50mm
Yes they knock like fuck
I'll start......
