Headgasket #YB1009/1 ?
I removed the head on my 4x4 a few days ago to have it freshen-up a bit and found YB1009/1 stamped on the gasket. Is this a standard gasket? What would you fellas recommend as a replacement? My plans are not to go past a stage 2 since I'm in the US and 4x4 trans are not available here. I will also be using the standard head bolts... had a bad experience with ARP studs on a previos project (cracks on the surface of the block
Wes.
).Wes.
Originally Posted by Doug Stirling
Originally Posted by TIFF-C20WTH
As said above, Late Escort Cosworth gasket will be fine
It is called: YB 1261
the yb0611 "group a" one is no better at all, just twice the price
Ok now I know what I need, can anyone tell me what I had? (YB1009/1).
Just trying to determine if the gasket was replaced before. BTW my bud at the machine shop could not believe his eyes when he saw the cam bearing in the head (he has never seen anything like it) and thinks it will probably outlast the engine. Also found out that the valve steam seals are from a BMWs (not sure which model).
YB 1261 its is
Erik where your credit card?
Seriouly dude I'm going to have to forward my paychecks to you.
Wes.
YB 1261 its is
Seriouly dude I'm going to have to forward my paychecks to you.Wes.
Ok Svony you have saved me asking this but i could do with some more info.
I have a Small turbo escort cossy that runs around 270-280 hp has done around 38,000 miles and i surspect the head gasket is going ( done a test with blue fluid tured yellow)
Now as mine in the late type car 1996 this should have the YB1261 ?? so what do i repalce it with ?? as it has gone with a low BHP car and what about ARP studs and what is the WRC one like
I am going to change it to Big trubo spec soon
Any ones help would be nice
220TC
13
Oct 25, 2004 11:22 PM
simonc
Jul 24, 2004 04:46 PM
simonc
11
Jun 30, 2004 11:16 PM
