What oil type and any tips on oil change?
Old Apr 14, 2009 | 06:11 PM
Mike_SS's Avatar
Mike_SS
Default What oil type and any tips on oil change?
Am doing an Oil change on my 2005 1.6 Focus tomorrow. Not sure what oil to get though? 5w30? 10w40?
Any special instructions for the oil change or is it just the standard method?
Old Apr 14, 2009 | 06:25 PM
tarmac terriost's Avatar
tarmac terriost
5w30 m8ty and dont use engine flush !!!!!
Old Apr 14, 2009 | 06:47 PM
Mike_SS's Avatar
Mike_SS
Cheers dude.
I'm sure I've got some 10w40 knocking about and was hoping to use that. Not much between them so may well still use it
Old Apr 14, 2009 | 07:23 PM
RichieST's Avatar
RichieST
Crikey, dont use 10/40, it'll knacker the hydraulic lifters in no time!
Ford petrol engines are designed for 5/30.....
Old Apr 14, 2009 | 09:06 PM
woolford's Avatar
woolford
why cant you use engine flush?? and why will 10w40 knacker the lifterd??
Old Apr 14, 2009 | 11:05 PM
tarmac terriost
the 10 w40 is to thick for the tappets it will be like treacle and will cause sticky valve cindrome and not open the valves properly or worse cases drop a valve into the pistions or knacker the oil pump up
you should never engine flush a ford engine in fact any engine as it takes the dirty/carbon build up and moves it around and could block a oil gallery or knacker up the oil pump !!!
thats why you dont do it, cost lots of money to fix all because of Ł3.99 bottle of crap was used so big no no no !!
Old Apr 15, 2009 | 05:21 PM
woolford's Avatar
woolford
wups.. when i start my focus up in the morning blue smoke come out the exhaust not so much when it warms up but when i boot it blue smoke again.
Old Apr 15, 2009 | 05:33 PM
pani_k's Avatar
pani_k
PassionFORD Member
As said above really 10W-40 is too think and causes sticky valves.
And as for engine flush, general consensus always been unnecessary as if you change the oil regularly enough, use decent quality oil and rev your engine properly then everything will be fine.
Old Apr 15, 2009 | 05:53 PM
woolford's Avatar
woolford
so hopefully if i change the oil filter and oil without flushing it and drive it hard the blue smoke should clear up..
Old Apr 15, 2009 | 06:02 PM
pani_k's Avatar
pani_k
PassionFORD Member
What oil are you using and have you flushed the engine before?
Old Apr 15, 2009 | 06:09 PM
tarmac terriost
if i was you change the oil and filter see if it clears up if not sounds like a valve stem oil seal gone down or a piston ring still means a rebuild either way
Old Apr 15, 2009 | 06:44 PM
woolford's Avatar
woolford
I have flushed the engine before.. and oil is 10w 40..
Old Apr 15, 2009 | 07:34 PM
pani_k's Avatar
pani_k
PassionFORD Member
As said above get that oil out of there and get proper 5W-30 in. Get a cheapo 5W-30 in for 1000miles first and then drain it and refill with a decent 5W-30 and see what happens.
Old Apr 15, 2009 | 08:12 PM
woolford's Avatar
woolford
will give it ago bud cheers
Old Apr 15, 2009 | 08:23 PM
tarmac terriost
putting 10w40 in properly has killed that engine !!!!!
silly thing to do really for the sake of Ł24 pound for some 5w30 its going to cost more like Ł500 to rebuild the head ,like i said same as the other change the oil see how it goe's
Old Apr 15, 2009 | 08:29 PM
woolford's Avatar
woolford
silly cunt i am.. ill change it asap..is a head hard to rebuild as i have spair lifters etc
Old Apr 15, 2009 | 08:52 PM
tarmac terriost
hmm right change the oil and filter see how it goes if it doesn't clear strip the head down and check oil the valves make sure they are not burnt out replace all the oil stems seals and replace the tappets
is your blk top or silver top zetec ?
if blk top engine will have to re shim it as they are soild tappets
if silver top is hydraulic its a straight followed swop over but use proper assemably paste on the job too on both engines what ever you run also use a std ford head gasket and make sure get the head lightly skimmed
Old Apr 15, 2009 | 09:00 PM
woolford's Avatar
woolford
black top mate
Old Apr 15, 2009 | 09:12 PM
Mike_SS's Avatar
Mike_SS
Didn't get around to it today as the brakes were a nightmare to do!
Will do the oil tomorrow and use some 5/30
Old Apr 15, 2009 | 09:24 PM
siemens's Avatar
siemens
but black tops solid lifters!!!!!!!!!!!!!!!!!!!!!!!!!as you say???
Old Apr 15, 2009 | 09:30 PM
tarmac terriost
blk top is still 5w30 oil as well in fact all fords are 5w30
aprt from cossie's and the old school diesel escorts/mondy's which run 10w40 which is correct
mk22door
49
Mar 26, 2022 07:15 AM
JK12
33
Apr 26, 2021 12:09 PM
StephTell
Sep 2, 2015 06:31 PM
oilman
Trader Parts for Sale.
Aug 30, 2015 08:37 AM
cameron2
Aug 25, 2015 07:18 AM
