pic of the wiring behind the dash on a S2?
Does anyone have any pic's of the wiring loom behind the dash, im putting my loom back in and i cant remeber were parts of the loom run.
Shaun
Shaun
here you go mate
just joking. what colours and shapes are the ones your stuck with. once you've got it layed out its all pretty logical imo.
from complete memory, from left to right
red+ yellow single wire, interior door light switch.
glovebox light cant remember.
heater box illumination grey + yellow and brown on a small black connector
cig lighter, cant remember
radio, brown and black "L" shaped connectors, one power, one speakers. aerial is already there.
yellow block connectors are indicator and wiper stalks (they each only fit the right ones)
blue and white "I" shaped connectors are rev counter and fuel/temp guage with illumination. these are colour coded on the back of the clocks to which one fits where
if you have a fuel computer the block connector for that is also around there somewhere too.
if you've got leccy mirrors, windows and locking, there are three "triange" shaped connectors located close to the fusebox hole. these are red yellow and black, the respective looms run to different places obviously. then the relays go above the speaker in the drivers side footwell.
another red + yellow wire, interior light switch for drivers side
sorry if it seems amateur or its of no help but i tried
if you "lay" it all out inside the car with the dash out it should work itself out pretty easily.
Ive had a look through my pictures and these 2 are the best ive got
the only thing thats wrong with them pictures is the route for the wiper stalks wireing it doesnt want to be feed through under the steering columb bracket as then it wont reach the stalks as i found out and had to take the dash back out
u know exactly what ive done the other day dont u lol.
JK12
33
Apr 26, 2021 12:09 PM
3dr cossie
Alloy wheels and ICE for sale
Sep 2, 2015 08:58 PM
