Zetec turbo breather drilling
Hello,
Put this in the tech section but thought id get more response here...
I'm at the stage where I need to sort out the breather for the block. I have sent the sump to Ian Howell to install the turbo drain so thats sorted. I have focus RS pistons and rods, inlet sorted and ERST exhaust manifold with cossie T3. I dont really wan to drive the block to lincoln to Ian just for this job so...
How difficult is it to do the block and what do you use as a stub, where do you get the stubs.
Any help gratefully received.
Mart
Mart
Hello,
Mart
Mart
about 1mm small than the tap size
hope this help
cheers paul
Is there anywhere specific I should be drilling? is it better on the thicker place or on the thinner wall?
I will email Ian as well as he still has the sump yet.
Thanks for the help
Thanks for the help
