Bending a stainless exhaust?
Old Apr 11, 2009 | 11:46 AM
Stu @ Claims Care Centre's Avatar
Compensation Specialist
Default Bending a stainless exhaust?
another problem
i have converted my downpipe flange to vband.
now for some reason its about 5mm from going on turbo square because the other end of the downpipe is hitting the gearbox cradle. so i need to slightly bend the downpipe down more so the flange sits correctly.
ive tried to put it in a vice and bend it but dont move
can i heat it at a bend would it be a lot easier then, like said i only need 5mm.
Old Apr 11, 2009 | 12:02 PM
Red16's Avatar
Red16
Have you not got a local Powerflow type of place to go to, they could bend it with a mandrell inside the pipe to stop the pipework from distorting/creasing while its being bent, plus they have a bending machine which will take all the effort out of it and get he bend closer to what you actually want it to be, plus it'll cost you next to nowt.
Old Apr 11, 2009 | 12:07 PM
like i said its only 5mm so should take them litrally secs
Old Apr 11, 2009 | 12:20 PM
zetaboostboy522bhp's Avatar
zetaboostboy522bhp
hi mate youll be lucky to bend that in a vice like the bloke said above mandrel bend it but dont use powerflow as they use crush type benders , or cut nearly all the way through it and then bend it shut and reweld it if your in a rush or send it to ojz engineering in lincoln as they have a quick turn around
Old Apr 14, 2009 | 03:55 PM
went to a local powerflow dealer they wanted to cut it and weld it at a different angle
5mm is all im asking to be bent by.
Old Apr 14, 2009 | 04:03 PM
Garage19's Avatar
Garage19
Bending 3" thin wall stainless is tricky. I would cut it and weld it!
Old Apr 14, 2009 | 04:29 PM
SillyFezzaMk1's Avatar
SillyFezzaMk1
Rubber Rhino Crew
cut and weld is probably the best way of doing it from your description, you could do it gearbox end so its not in sight?
dan
Old Apr 15, 2009 | 11:35 AM
Just sit on it, your weight will soon bend it!!
Old Apr 15, 2009 | 01:21 PM
pot kettle black
Old Apr 15, 2009 | 02:38 PM
So true so true!!
Nov 1, 2015 06:53 PM
dalmarshall
Ford Classics & Vintage
Oct 1, 2015 06:46 PM
XR4
Ford XR Range
Oct 1, 2015 12:46 PM
stevecfrst1
Sep 30, 2015 05:18 AM
