Boost Gauge
Old Apr 9, 2009 | 02:36 PM
white2lsr's Avatar
white2lsr
Default Boost Gauge
This is the first time I have owned a turbo'd car. Im just wondering where the boost gauge should sit when you are just cruising along. Mine sits on the wrong (negative) side of zero. Is this correct?
Old Apr 9, 2009 | 02:44 PM
Micky's Avatar
Micky
Yes it is.But if you put youre foot down it will move into the positive side of the guage.Regards,Micky
Old Apr 9, 2009 | 02:48 PM
Chopshop85's Avatar
Chopshop85
yeah boost gauges messure vacuum pressure or something along those lines (correct me if im wrong) until the turbo spools which is when it well pick up through the positive.
Old Apr 9, 2009 | 02:50 PM
white2lsr's Avatar
white2lsr
Its very slow to spool up, about 3K revs boost comes in. Is this usual or will the actuator have been played with? Ill be getting it set up on the rollers once i get the crank reground and fit new bearings.
Old Apr 9, 2009 | 02:53 PM
Micky's Avatar
Micky
Around 3k or a little under is normally when the turbo starts to make boost.Regards,Micky
Old Apr 11, 2009 | 06:25 PM
nickrsturbo1990's Avatar
nickrsturbo1990
i used to have a t34 on my erst what a lag moster that was lol off it came haha didnt spool till nearly 4k lol
timsrs
Nov 13, 2018 11:48 AM
Nov 1, 2015 06:53 PM
Mark RS
Oct 12, 2015 06:01 AM
Russ Payne
Sep 25, 2015 08:29 PM
CrOwSoN15
14
Sep 3, 2015 12:21 PM
