mk5 with rs lump fitted
Old Apr 7, 2009 | 05:53 PM
scortpower's Avatar
scortpower
Default mk5 with rs lump fitted
since deciding to sell my mk5 escort it has got a missfire. i have replaced plugs so far.
the problem is it start to missfire one boost and also once the car is warm it will not start. when its cold its ok but as soon as you go 2 mins down the road switch it off it dont wanna know. now its getting a spark! now i have had a listen to the engine and i can hear a hissing sound from behind the manifold which i think is auxilly air valve. i can wiggle some black pipe and the hissing noise changes tone. now could this be my problem ? i cant find my rs turbo haynes manuel!
any help will be great
Old Apr 8, 2009 | 11:04 AM
orion88's Avatar
orion88
got a leak by the sound of it
get that sorted and itll be fine
Old Apr 8, 2009 | 12:02 PM
Karlos G's Avatar
Karlos G
Balls Deep!
Yeah i had this and it was the black pipe going from the AAD to the inlet manifold, the rubber insert had split.
Old Apr 15, 2009 | 10:07 AM
scortpower's Avatar
scortpower
right will take the pipes off tonight hopefully then, i hope thats what it is. it just suddenly started doing it and its only when i had a listen the other day i could hear a bit of hissing. why would it start when its cold?
Old Apr 15, 2009 | 04:32 PM
orionmojo's Avatar
orionmojo
is it this pipe?
does your engine do this?
Old Apr 15, 2009 | 08:44 PM
scortpower's Avatar
scortpower
yeh thats the pipe i moved it and the hissing tone changed! will have to take it off then and have a look
Old Apr 15, 2009 | 08:45 PM
scortpower's Avatar
scortpower
yeh the engine will start then cut out at times ! starts ok then its cold thou
Old Apr 15, 2009 | 09:20 PM
orionmojo's Avatar
orionmojo
i dont know if its a bodge fix but i wrapped some ptfe tape rouned mine and put it back on, its been sound for over 6 months now.
Old Apr 17, 2009 | 01:38 PM
scortpower's Avatar
scortpower
right i took pipe off didnt seen any splits but i did a bodge fix with tape. will put it back on. i am wondering now if its the other blackpipe which goes from the breather to the fuel metering unit as i cant see what else will be hissin. i will try get the pipe back on later
Old Apr 17, 2009 | 02:08 PM
Karlos G's Avatar
Karlos G
Balls Deep!
It should have a rubber insert inside like this one you can see split!
Old Apr 17, 2009 | 02:45 PM
orionadam's Avatar
orionadam
orion
my mates mum escort does this it cuts out when u slow down to fast it the inlet pipe from the inlet manifold just needs cleaning
JoeyBoyden
Jan 4, 2024 02:36 PM
Chas
Sep 21, 2015 08:57 PM
RockinRein
Aug 19, 2015 07:08 PM
Seanyfarrell
Aug 14, 2015 11:37 PM
turbobill
Aug 1, 2015 08:55 PM
