rs turbo and xr3i head?
Old Apr 2, 2009 | 09:27 PM
mikey_clough's Avatar
mikey_clough
Default rs turbo and xr3i head?
hi all, is there any difference in say a mk4 xr3i head and a mk4 rs turbo head? i know mk3' s are different port shapes ect. but in need of a new one and dont see the point in paying extra for a head jus because it came of a turbo! cheers
Old Apr 2, 2009 | 09:29 PM
B16CVH's Avatar
B16CVH
No real difference apart from the exhaust valves being sodium filled
Old Apr 2, 2009 | 09:31 PM
mikey_clough
ok, you lost me at sodium? does this affect or do anything?
Old Apr 2, 2009 | 10:03 PM
B16CVH's Avatar
B16CVH
The exhaust valves are sodium filled to help them cope with the higher temps generated by the turbocharged engine
Old Apr 2, 2009 | 10:06 PM
mikey_clough
learn something new everyday! could you still use a 3i head then or would it just crack and make all kinds of mess...
Old Apr 2, 2009 | 10:09 PM
B16CVH's Avatar
B16CVH
You will be fine with the XR3i head providing you change the valves, would be better to buy some new stainless ones as the original ones are getting old now (unless you can get new std ones cheap) etc
Old Apr 2, 2009 | 10:11 PM
mikey_clough
ill do that then, cheers for the info bud
Old Apr 2, 2009 | 10:28 PM
Karlos G's Avatar
Karlos G
Balls Deep!
Only the S1 heads that had sodium filled exhaust valves and they just dissipate heat easier not important at all mate.
Full set of standard valves are about £45 off ebay!
Old Apr 3, 2009 | 05:44 AM
cabrst's Avatar
cabrst
as above...its ONLY the S1 that runs sodium filled
3i Jim
Nov 20, 2015 05:12 AM
Matt Baxter
Sep 16, 2015 08:30 PM
Marcus L
Aug 29, 2015 02:18 PM
Dahl88
Aug 22, 2015 08:16 PM
marky_g
Aug 15, 2015 10:43 AM
