Bhp figure
so i had the beast set up on the r/r yesterday
anyone wanna guess the bhp output?
its a 1.6 efi engine stage 3 t3 turbo
superchip
10psi
closest person gets a smartie
superchip
10psi
other than the mods listed
nothing other than 301 webber injectors
the engine was from a breakers so other than me changing the head gasket ive no idea
im pleased tho
im pleased tho
its capable of a lot more but the clutch started slipping so i need a new one of them next and its on the standard intercooler so yea im please im only looking for the 200 mark anyways so i dnt think ill struggle
karlos ur smartys been posted
Not that i don't believe that's what your printout said but 184bhp at the wheels with just 10psi and a standard intercooler is very optimistic imo, in fact as i'd go so far as to say it wouldn't actually be that power in reality.....
I don't think youre car made 184 BHP at 10 psi,no matter how much the turbo was modified!!!Standard head,std cams and a std interwarmer!!!Bloodly hell,I must get my car on them rollers,it will make 600 BHP!!!!!
Micky
well yeh, this was what my initial reaction was too, but didnt wana rain on the kids parade lol
i think its safe to say you could estimate the power more accurately yourself by attempting to bite down on the wheel with your own teeth, as opposed to trusting their rollers
hahahahaha hvae they got a rep for not being that accurate then?
like i said i have no idea what been done to the engine other than what i have done which the above listed
im not here to prove my point i was merely having a bit of fun
some of yas need to pull the brooms out ur asses
lol dont take it to heart mate, im not dissing your motor, just hi-tec always seem to supply rather questionable results
a while ago a lad i know came back with a power figure at the wheels higher than my fly figure i got after my session down jamsport. this is bearing in mind his car was standard except a chip and actuator, and running 5psi less than mine
but the main thing is so long as your happy with it and it keeps u sweet, then no real worries man, and if your that worried about gettin a more accurate power figure, now its set up at least u can just pop along to a RR day for a cheap power run at somewhere reputable
TBH RR BHP figures are pretty much useless, no two are alike and no two operators do things exactly the same!
Great for setting the car up though, fuelling, timing, boost etc...
If you want real BHP figures then an Engine Dyno is the only accurate way to do it IMO.
Orion88 I agree people take things too seriously on here and indeed a lot brooms need removing PMSL!
ahahaha i dnt take it personally at all
im happy that it runs properly and is fueling great to be honest im getting 35mpg as opposed to my 15 and the boost spluttering is gone so for that the session was totally worth the money
just nice to have a figure in mind and a starting post to go from
Can i borrow this topic? I am currently building new engine and i want to know approx power what it will give.
And the specs:
-1600 rst bottom end rebored + 0.5mm
-EFI Head with matched intake+exhaust manifolds, reconditioned head with some porting.
-Piper 285T2 cam kit & adjustable pulley properly timed.
-EFI intake manifold (matched), 380cc injectors
-Megasquirt efi ecu+wasted spark
-Std exhaust manifold & std t03 turbo+31 actuator
-Mongoose 2.5" bore exhaust
-Pipercross filter
-Airtec big cooler
I am thinking something like 18-19 PSI of boost. 200 bhp from the engine?
And the specs:
-Pipercross filter
-Airtec big cooler
Antti O- yeah you wont be far off with a decent intercooler.. dont bother with the piper cam, they're not great on 1.6 engines.. drop the compression ratio and fit a larger turbo and you'll be in a much better position.
I am afraid that 285t2 is so "high rev" cam so is useless but i think i give a try. I will get larger turbo & better exhaust manifold in next winter, but this "first summer" i am gonna drive with this package. Can std t03 handle 18-20psi?
