cossie brake upgrade?
im going to be doing the upgrade on my s2 usng 4x4 calipers and 2wd disc, can i use the s2 flexi hose or are they to short, i know most people change to braided hoses.
yes i've read the stickied at the top, yes im useing std 2wd cossie disc 283mm, i know i may have to file a bit off in places and use a spacer between the carrier and caliper, just didnt want to start the job and find out the hoses are to short!!!
thanks for all the info hope to have them on by the weekend!!!
in all honesty if you just buy the brackets that allow you to push your origional caliper out to accept the cossy disc then you'll save some money and imo it brakes better like that too.
That's not to say you are wrong, each to their own.
Any yes, the cossie caliper is bigger, as is the piston, but the same ammount of force is applied to the piston by the M/C. But there is much more brake pad surface area, much more.
But to answer to your original question, as stated, you can use your original hoses!
Lee
The Enigma
Sep 12, 2015 10:12 PM
