erst stem seals
Old Mar 29, 2009 | 07:06 PM
Korda's Avatar
Korda
Default erst stem seals
need to change my stem seals has the head got to come off,
also how much do they cost and any other parts i need thanks
Old Mar 29, 2009 | 07:15 PM
cj_rst's Avatar
cj_rst
S2 RST
Nope, get yourself a CVH valve spring compressor and you won't need to have the head off. Cost about £7 from Burtonpower. Stem seals cost about the same for a full set IIRC. Cheap and easy to do but don't drop your valve collets down the oil drains or it's sump off time...
Old Mar 29, 2009 | 08:55 PM
Karlos G's Avatar
Karlos G
Balls Deep!
Yeah as above easy job mate
Old Mar 29, 2009 | 09:11 PM
orion_crazy_carl's Avatar
orion_crazy_carl
orion=mini saff
set off ebay for 3.50!make sure u get the top hat ones!quick tip, when u compress it to get the collets out, put the piston to the top stops it dropped and makin it harder to get them out!
Old Mar 29, 2009 | 09:20 PM
s1cab's Avatar
s1cab
yeah as above do cylinders 1 & 4 together then 2 & 3 just make sure pistons are up ! should take bout an hour.
Old Mar 30, 2009 | 01:04 PM
cj_rst's Avatar
cj_rst
S2 RST
lol yeah definitely make sure the pistons are up when you do this, I *nearly* got a valve stuck when I did my stem seals...
Old Mar 30, 2009 | 04:00 PM
Korda's Avatar
Korda
will do im buying the set today to fit the weekend
Cosnada
Jan 7, 2016 05:30 PM
Nov 1, 2015 06:53 PM
Mc5506
Oct 5, 2015 09:57 PM
muzzman1
Sep 30, 2015 08:59 PM
