what do i need to wire a oil pres gauge.
Apart from the gauge
its an electric fed one not by oil if you know what i mean. what do i need for the fitting in the back of the engine ( t piece ) cheers
When i done my gauges i bought a sandwich plate off ebay the bolts to the oil filter housing then you bolt your oil filter to that then just screw the sender into the sandwich plate with abit of ptfe tape (to make a good seal) plug the other holes and away you go
TPM961
Jan 15, 2018 10:50 AM
