HELLO ... help please
Hello not too long ago passed my driving test and bought me a ford escort 1.6 LX its ok but me being me want to iron out a few of the problems.. Its only done 34k on the clock and was bought off my mum's sister. but her sister isn't the best driver so i've a few problems i need to iron out.
1. the Reverse lights don't work, its not the fuse or the bulbs so i'm guessing the switch.. i've enclosed a pic wondering if i'm hot or cold. if so do i just need to replace?
2. The powersteering resevoir seems to have a leak is this common in fords?? just its a two piece heat sealed resevoir and seems to leak ever so slightly at the seem.
3. Brake pads are they easy to change?
4. I know its a ford and its only 1.6 but can i make it more punchy i'm not bothered about speed overall just want it to be quicker of the mark.
5. Cracked Bumper( my brother did this
) how do i fix it? or whats the best advice?
6. i've an oil leak any ideas what it could be and how to fix
and last but not least a pic of my Engine any advice or help is more than appreciated as i've never dabbled in car mechanics but i can build a mountain bike so reckon i'll be ok with a car.
Thankyou..
Thankyou..
that is the reversing light switch, not heard of one just stop working before tho...
again, not heard of one just start leaking, but get another from a scrappie, will cost about Ł5
yes, remove wheel, then on caliper at the bottom there is a small retaining clip, remove that with pilers, then punch out the pin, then pull the caliper towards you to enable it to swing up, remove pads, copper grease the new ones and replace
the 1.6 is a waste of time and money to try and tune, lots of money for very little gains. best bet is to put a 2.0l zetec in, like mine
that looks pretty terminal, again, another one wont cost much to replace
that is the thermostat housing, so its leacking coolent from their, not oil. try slightly loosening the bolts of the housing, only 1/4 turn, as if they are overtightened its possible that they leak. if that dont work get a new seal
Thankyou..
) how do i fix it? or whats the best advice?that looks pretty terminal, again, another one wont cost much to replace
Thankyou..
if you want more info on escorts go to www.FEOC-UK.com
HTH
First pic is your Switch that activates your reverse lights,oil leak pic i'd suggest a new rocker cover gasket...easy to change and cheap,Brake pads easy to change, just 2 bolts holding the calipers on...shouldn't be too difficult,just remember to copper grease the back of the pads and caliper area so they don't squeek.to make it more punchy how bout an filer element from KnN or summit? maybe a service i.e leads and plug change too,injector cleaner also? just some ideas
