Turbo Cabby Exhaust
Old Mar 26, 2009 | 02:41 PM
notroubleclubber's Avatar
notroubleclubber
Back In The RS Game!
Default Turbo Cabby Exhaust
I have a mk4 turbo cabriolet with s2 engine running mfi. However since fitting the engine and the aftermarket exhaust it dont seem tDoes the erst s2 exhaust fit properly to the cabriolet shell? Or has anyone had any probs or is it just my magnex exhaust needs repalcing as they are crap make?
o mount well and is always knocking or grinding on bumps etc.
Old Mar 26, 2009 | 02:46 PM
Turbocabbie's Avatar
Turbocabbie
Top Cab !!
Get a 3 inch mongoose you will have no issues
Old Mar 26, 2009 | 02:51 PM
cabrst's Avatar
cabrst
the standard S2 exhaust will fit fine ( i use to run that on my cab )
as for aftermarket ones there are good and bad ones, but as above the mongoose fit well...
Old Mar 26, 2009 | 02:57 PM
orion88's Avatar
orion88
i had a mongoos on my cab of an rst and it seemed to be too long at the rear looked stupid but i got it shortened when i had the baffles took out.
Old Mar 26, 2009 | 03:24 PM
sm's Avatar
sm
a s2 exhaust fits a cabbie fine, there prob nothing wrong with the magnex, it prob just needs refitting and taking time to adjust each section properly before tightening it all up
Old Mar 26, 2009 | 03:27 PM
Karlos G's Avatar
Karlos G
Balls Deep!
I run a Magnex on my cabby no problem at all.
Old Mar 26, 2009 | 05:13 PM
safcdixon's Avatar
safcdixon
SAFCDIXON
i have a scorpian s/s exhaust and it catches the rear arm not bad in terms ov damage but enough too piss ya off after a couple ov minutes when drivin slow and there is no mounting at the front were the middle section joins the front pipe it hangs low down and ive ripped it off once on a speed hump so dont get a scorpian
Old Mar 26, 2009 | 06:54 PM
RSmark84's Avatar
RSmark84
were does it knock?
my scorpion exhaust banged on my rear arms/baffle plate, so i had another bracket welded onto the chassis and pipe, sorted it out straight away.
Old Mar 27, 2009 | 02:02 PM
notroubleclubber
mark : thats where its vibrating a believe.Also the middle to front section has a bracket but looks snapped off so cant reach to put another rubber on. Might just get hold of another exhaust.Got ats to have a look and i had a look myself whilst it was on the ramp. Sorted a few things so its not so bad now but will need sorting.
Old Mar 27, 2009 | 06:08 PM
RSmark84's Avatar
RSmark84
the one you say that looks snapped of isn't, on the chassis there is a mounting for an exhuast bracket which isn't used.....not sure on the cabriolet.
The scorpion exhuast didn't have the bracket fitted, someone else i know had to have a bracket fitted in the same place i had to have mine done, get yourself upto BELL exhuast centre 30 min job they will fit another bracket on exhuast/chassis, remove all underseal and fit the rubber for £40.
Matt Baxter
Sep 16, 2015 08:30 PM
EoinXR3
Sep 7, 2015 05:44 AM
rsstav
Ford Focus RS Parts for Sale.
Aug 20, 2015 07:45 AM
IAN RS2k
Aug 18, 2015 07:51 PM
rsstav
Ford Focus ST Parts for Sale
Aug 11, 2015 04:19 AM
