adjustable track arms, make front end light?
Old 24-03-2009, 08:25 PM
AJ-RST1
The posh are up!!!
AJ-RST1's Avatar
Default adjustable track arms, make front end light?
as above fitted my new tcas, took her for a drive and the front end is so light now is thi normal?
Old 24-03-2009, 09:09 PM
project rs
project rs's Avatar
mine never changed, are they set to match standard length or you had them set up to match your specific car
Old 24-03-2009, 09:23 PM
AJ-RST1
The posh are up!!!
AJ-RST1's Avatar
in theory it make the steering lighter cuz if you have camber, it makes the steering harder,then pull wheels straight less drag so should make it lighter.
Old 24-03-2009, 10:21 PM
iansoutham
OCD Victim
iansoutham's Avatar
Check and adjust the tracking, chances are that the camber is less than it was before and most likely, the toe is more positive (toeing in instead of out). This will make the front end more twitchy and light-feeling.
Old 25-03-2009, 09:30 PM
Rick
Rick's Avatar
toe in makes the car less twitchy.
Old 27-03-2009, 01:17 AM
Micky
Micky's Avatar
@Rick,so will toe out make a rst turn in better????Regards,Micky
Old 27-03-2009, 08:25 AM
Rick
Rick's Avatar
yes mate, but makes it more twitchy. The Ford Rally prep book I have from 86 recomends 30miins toe in for straight stuff and 30mins toe in for twistier stages, giving a better turn in. You can probably push that to 1.5 degrees either way too.
Old 27-03-2009, 06:43 PM
NUTS RuS
NUTS RuS's Avatar
Check and adjust your toe on the steering arm.
If you have altered the camber on the TCA you need to re adjust toe !!
What camber are you running ?
Wilsfoci
15
30-03-2016 10:26 PM
track.focus'd
12-08-2015 05:53 PM
Bezzy41
03-08-2015 10:31 AM
Quick Reply: adjustable track arms, make front end light?
