adjustable track arms, make front end light?
Check and adjust the tracking, chances are that the camber is less than it was before and most likely, the toe is more positive (toeing in instead of out). This will make the front end more twitchy and light-feeling.
yes mate, but makes it more twitchy. The Ford Rally prep book I have from 86 recomends 30miins toe in for straight stuff and 30mins toe in for twistier stages, giving a better turn in. You can probably push that to 1.5 degrees either way too.
Check and adjust your toe on the steering arm.
If you have altered the camber on the TCA you need to re adjust toe !!
What camber are you running ?
Wilsfoci
15
Mar 30, 2016 10:26 PM
track.focus'd
Aug 12, 2015 05:53 PM
