Horn not working
Hi, i fitted a new aftermarket steering wheel and connected all the wires up on the boss ok with the correct ring and everything but horn is not working. I had swapped the loom round into my cab (s2 loom) and ive put one plug back on the horn that i labelled horn but i have a spare wire with a spade on the end of it that is black with white stripe and its next to the horn.Is this an earth for the horn,if not where does it go?
JK12
33
Apr 26, 2021 12:09 PM
Jack and the Beanstalk
Aug 15, 2015 04:27 PM
